PIC18F458 and CAN
Johannes
PIC18F458 and CAN
PostPosted: Mon Mar 31, 2003 5:03 am     Reply with quote
I designed a project before where I have used the PIC16F877 and the MCP2510 CAN controller.
Now I need to do another project and I want to use the PIC18F458 which has CAN built in.
My questions are as follows:
Can I use the exact same CAN driver as is written for the CAN18CXX8.C, CAN18CXX8.h? I asume so but need to get an answer.
Does the CAN controller on the PIC18F458 have the same problems as listed for the MCP2510 (according to erratra sheet) ?
Original Post ID: 13248
Re: PIC18F458 and CAN
PostPosted: Mon Mar 31, 2003 12:26 pm     Reply with quote
:=I designed a project before where I have used the PIC16F877 and the MCP2510 CAN controller.
:=Now I need to do another project and I want to use the PIC18F458 which has CAN built in.
:=My questions are as follows:
:=Can I use the exact same CAN driver as is written for the CAN18CXX8.C, CAN18CXX8.h? I asume so but need to get an answer.
Well, this can be found by using the search function of
the board (of course, I also knew it was there).
<a href="http://www.pic-c.com/forum/general/posts/12547.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12547.html</a>
:=Does the CAN controller on the PIC18F458 have the same problems as listed for the MCP2510 (according to errata sheet) ?
Couldn't that answer be found by comparing the two errata
sheets:
<a href="http://www.microchip.com/1000/suppdoc/errata/index.htm" TARGET="_blank">http://www.microchip.com/1000/suppdoc/errata/index.htm</a>
Original Post ID: 13257
