Rounding numbers down
oxxyfx
PostPosted: Thu May 29, 2008 1:13 pm     Reply with quote
Hi guys, some of you were born already knowing the C language, while I started learning it - because of the PIC MCU's - when I reached 41... Smile
So here is my question and I hope that somebody can give me an answer to this soon:
The MCU is a 12F629 PIC.
The thing which I want to achieve is to round a number down. For example:
I have a variable which is calculated to be = 1522. I need to round this - always down to 1500. The variable is defined as an int16.
So what I was thinking to do this easily is to divide the number by 100, which should give me 15.22, but since the variable is defined as an INT it will loose the decimals, automatically giving me a 15 as a result. At this point I could multiply the variable back with 100 to get the straight 1500 as a result.
Will it be like this, or some kind of unknown (by me) buffer will keep in mind the decimals and when I multiply it back it will be the same as the original number?
Thanks.
Ken Johnson
PostPosted: Thu May 29, 2008 1:41 pm     Reply with quote
Should work as you describe - no secret buffers Smile
Ken
RArtz
PostPosted: Thu May 29, 2008 1:56 pm     Reply with quote
thats how ive done it in the past.
Charlie U
PostPosted: Thu May 29, 2008 3:48 pm     Reply with quote
How about y= x-(x%100),
1500 = 1522 - (1522 % 100)
1522 % 100 = 22
