Help me
balamagesh
Help me
PostPosted: Sun Dec 29, 2002 10:19 pm     Reply with quote
i am using ex_extee.c with external EEPROM (93LC46B which is a 16 bit) how to convert 9346.c which is the 8 bit version of the abvoe mentioned External EEPROM. help me
Original Post ID: 10319
Re: Help me
PostPosted: Mon Dec 30, 2002 5:05 pm     Reply with quote
I am using ex_extee.c with external EEPROM (93LC46B which is a 16 bit)
how to convert 9346.c which is the 8 bit version of the above mentioned
External EEPROM.
I modified the CCS example file 9346.c to make it work
with the 93LC46B.
These routines expect a 16-bit data word. So you have to
send and receive a "long" variable to the read and write
routines.
This file is not tested, since I don't have the EEPROM chip.
Hopefully it will work, but if it doesn't, you will have to
debug it. Also, make sure your hardware is wired correctly.
// Library for a MicroChip 93LC46B (x16 org)
// init_ext_eeprom();  Call before the other functions are used.
// write_ext_eeprom(a, d);  Write the byte d to the address a.
// d = read_ext_eeprom(a);  Read the byte d from the address a.
// The main program may define eeprom_select, eeprom_di,
// eeprom_do and eeprom_clk to override the defaults below.
#ifndef EEPROM_SELECT
#define EEPROM_SELECT PIN_B7
#define EEPROM_CLK    PIN_B6
#define EEPROM_DI     PIN_B5
#define EEPROM_DO     PIN_B4
#define EEPROM_ADDRESS byte
#define EEPROM_SIZE    128
#define hi(x)  (*((int8 *)&x+1))
#define lo(x) (char)(x)
void init_ext_eeprom()
   byte cmd[2];
   byte i;
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
   output_low(EEPROM_SELECT);
// Load the opcode and address for an EWEN instruction
// into a 2-byte array.
   cmd[0]=0x80;   // Address bit A4 = 1.
// Start bit = 1, Opcode = 0,0, and Address bit A5 = 1.
   cmd[1]=0x9;
// Shift the 2 byte array left by 4 bits, so it becomes 0x9800.
// This is the bit pattern shown in Figure 3-5 (EWEN Timing)
// of the 93LC46A/B data sheet.  It consists of the Start bit,
// EWEN opcode, and address.  The address is only 6 bits.
   for(i=1;i<=4;++i)
      shift_left(cmd,2,0);
// We use 9 clock pulses to send the Start bit, Opcode and Address.
   output_high(EEPROM_SELECT);
   for(i=1;i<=9;++i) {
      output_bit(EEPROM_DI, shift_left(cmd,2,0));
      output_high(EEPROM_CLK);
void write_ext_eeprom(EEPROM_ADDRESS address, long data)
   byte cmd[4];
   byte i;
   // Fill a 4-byte array with the Start bit, WRITE opcode,
   // address, and 16 bits of data.  This is 25 bits, total.
   cmd[0] = lo(data) << 2;
   cmd[1] = (hi(data) << 2) | (lo(data) >> 6);
   cmd[2] = (address << 2) | (hi(data) >> 6);
   cmd[3] = 0x5;    // Start bit = 1, and Opcode = 0,1
// Shift the 4-byte array left by 5 bits.
// This will left-justify the bits in the array.
   for(i=1;i<=5;++i)
      shift_left(cmd,4,0);
// Send the 9 bits of header information, and the 16 bits of
// data to the EEPROM.  This requires 25 clocks.
   for(i=1;i<=25;++i) {
      output_bit(EEPROM_DI, shift_left(cmd,4,0));
   delay_ms(11);
long read_ext_eeprom(EEPROM_ADDRESS address)
   byte cmd[4];
   byte i;
   long data;
// Setup an array with the READ opcode and the address.
// Fill in the unused bits with zeros.  These will be
// shifted out while we are shifting in the data from
// the EEPROM.
   cmd[0]=0;
   cmd[1]=0;
   cmd[2]=address << 2;
   cmd[3]=0x6;   // Start bit and READ opcode
// Shift the 4-byte array left by 5 bits,
// so that it's left justified in the array.
   for(i=1;i<=5;++i)
// Send out 25 clocks to the EEPROM.  The first 9 clocks
// will be the Start bit, Opcode, and address.
// The next 16 clocks will bring in the data from the EEPROM.
      if(i > 9)  // Clocks 10 through 25 bring in the data.
        shift_left(&data,2,input(EEPROM_DO));
   return(data);
Edit: Put it in a code block and updated the hi(x) function.
Original Post ID: 10340
balamagesh
Re: Help me
PostPosted: Tue Dec 31, 2002 11:45 pm     Reply with quote
Many thanks and i am using below main.c function to use 9346.c(16 bit version) which u gave.
main()
long add=0x0001;
long value=0x0011;
long data;
init_ext_eeprom();
write_ext_eeprom(add,value); // write_ext_eeprom
delay_ms(20);
data = read_ext_eeprom(add);
if there is any changes in the above code pls advice me to do the modifications
Original Post ID: 10376
balamagesh
Re: Help me
PostPosted: Fri Jan 10, 2003 12:31 am     Reply with quote
Thanks a lot PCM Programmer , serial EEPROm is working fine thanks for the 16 bit codeby the by ur name pls
:=:=i am using ex_extee.c with external EEPROM (93LC46B which is a 16 bit) how to convert 9346.c which is the 8 bit version of the above mentioned External EEPROM.
:=I modified the CCS example file, 9346.C, to make it work
:=with the 93LC46B.
:=These routines expect a 16-bit data word. So you have to
:=send and receive a "long" variable to the read and write
:=routines.
:=This file is not tested, since I don't have the EEPROM chip.
:=Hopefully it will work, but if it doesn't, you will have to
:=debug it. Also, make sure your hardware is wired correctly.
:=<PRE>
:=// Library for a MicroChip 93LC46B (x16 org)
:=// init_ext_eeprom(); Call before the other functions are used.
:=// write_ext_eeprom(a, d); Write the byte d to the address a.
:=// d = read_ext_eeprom(a); Read the byte d from the address a.
:=// The main program may define eeprom_select, eeprom_di,
:=// eeprom_do and eeprom_clk to override the defaults below.
:=#ifndef EEPROM_SELECT
:=#define EEPROM_SELECT PIN_B7
:=#define EEPROM_CLK PIN_B6
:=#define EEPROM_DI PIN_B5
:=#define EEPROM_DO PIN_B4
:=#endif
:=#define EEPROM_ADDRESS byte
:=#define EEPROM_SIZE 128
:=#define hi(x) (*(&x+1))
:=#define lo(x) (char)(x)
:=void init_ext_eeprom()
:= byte cmd[2];
:= byte i;
:= output_low(EEPROM_DI);
:= output_low(EEPROM_CLK);
:= output_low(EEPROM_SELECT);
:=// Load the opcode and address for an EWEN instruction
:=// into a 2-byte array.
:= cmd[0]=0x80; // Address bit A4 = 1.
:=// Start bit = 1, Opcode = 0,0, and Address bit A5 = 1.
:= cmd[1]=0x9;
:=// Shift the 2 byte array left by 4 bits, so it becomes 0x9800.
:=// This is the bit pattern shown in Figure 3-5 (EWEN Timing)
:=// of the 93LC46A/B data sheet. It consists of the Start bit,
:=// EWEN opcode, and address. The address is only 6 bits.
:= for(i=1;i<=4;++i)
:= shift_left(cmd,2,0);
:=// We use 9 clock pulses to send the Start bit, Opcode and Address.
:= output_high(EEPROM_SELECT);
:= for(i=1;i<=9;++i) {
:= output_bit(EEPROM_DI, shift_left(cmd,2,0));
:= output_high(EEPROM_CLK);
:=void write_ext_eeprom(EEPROM_ADDRESS address, long data)
:= byte cmd[4];
:= byte i;
:= // Fill a 4-byte array with the Start bit, WRITE opcode,
:= // address, and 16 bits of data. This is 25 bits, total.
:= cmd[0] = lo(data) << 2;
:= cmd[1] = (hi(data) << 2) | (lo(data) >> 6);
:= cmd[2] = (address << 2) | (hi(data) >> 6);
:= cmd[3] = 0x5; // Start bit = 1, and Opcode = 0,1
:=// Shift the 4-byte array left by 5 bits.
:=// This will left-justify the bits in the array.
:= for(i=1;i<=5;++i)
:= shift_left(cmd,4,0);
:=// Send the 9 bits of header information, and the 16 bits of
:=// data to the EEPROM. This requires 25 clocks.
:= for(i=1;i<=25;++i) {
:= output_bit(EEPROM_DI, shift_left(cmd,4,0));
:= delay_ms(11);
:=long read_ext_eeprom(EEPROM_ADDRESS address)
:= byte cmd[4];
:= byte i;
:= long data;
:=// Setup an array with the READ opcode and the address.
:=// Fill in the unused bits with zeros. These will be
:=// shifted out while we are shifting in the data from
:=// the EEPROM.
:= cmd[0]=0;
:= cmd[1]=0;
:= cmd[2]=address << 2;
:= cmd[3]=0x6; // Start bit and READ opcode
:=// Shift the 4-byte array left by 5 bits,
:=// so that it's left justified in the array.
:=// Send out 25 clocks to the EEPROM. The first 9 clocks
:=// will be the Start bit, Opcode, and address.
:=// The next 16 clocks will bring in the data from the EEPROM.
:= if(i > 9) // Clocks 10 through 25 bring in the data.
:= shift_left(&data,2,input(EEPROM_DO));
:= return(data);
:=</PRE>
Original Post ID: 10584
