How to test ?
How to test ?
PostPosted: Thu May 22, 2008 11:01 am     Reply with quote
hi,
i would like to test if port C3 is high or low in the programme
how can I do this
I use PIC 16F877
thank you
SherpaDoug
PostPosted: Thu May 22, 2008 11:23 am     Reply with quote
Look up input() in the help files. The term "port" is usually used for an 8 pin set, or a serial port. C3 is referred to as a "pin".
