erik006
| i2c troubles - again |
Posted: Thu May 08, 2008 5:50 pm |
I'm having i2c troubles again, with a very similar setup as last time.
Currently I'm using a 16F88 as the master device, and an 18F2431 as a slave device. Both running from the same supply. I have tried both 4k7 & 2k7 pullups on the i2c bus. The circuit seems to be ok.
As you can see in the code below, a led should turn on if the ISR on the slave is called. It never turns on. The printf in the master code returns 'ff'.
Both leds successfully blink, however, the slave seems to lock up sometimes.
Kind regards,
Erik
PS: compiler version 4.057 (poor student - can't upgrade)
Slave:
| Code: | #include <18f2431.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP
#use delay(clock=8000000)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C5, address=0xa0,force_hw)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
BYTE incoming, state;
output_low(pin_a2); //turn on a LED
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
void main ()
enable_interrupts(INT_SSP);
while (TRUE) {
//blink led
output_low(pin_a3);
output_high(pin_a3);
Master:
#include <16f88.h>
#use delay(clock=25000000)
#use i2c(MASTER,slow, SDA=PIN_b1, SCL=PIN_b4,force_sw)
#use rs232(baud=9600, xmit=PIN_b5, rcv=PIN_B2)
// Write the letter 'B' to the slave board.
int8 data;
printf("init");
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
// Read from the slave board and display the data.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1);
data = i2c_read(0);
i2c_stop();
printf("read %x \n\r", data);
while(TRUE){
//blink
output_low(pin_a0);
output_high(pin_a0);
Posted: Thu May 08, 2008 6:16 pm |
| Quote: | | #use i2c( SDA=PIN_C4, SCL=PIN_C5, address=0xa0,force_hw) |
This statement is missing the 'Slave' parameter. |
erik006
| Re |
Posted: Thu May 08, 2008 7:05 pm |
Good catch, PCM programmer, although that's not the problem. In trying to eliminate possibilities I tried a version without "SLAVE" although there's probably not much sense in that. It doesn't work with slave added either. (I edited my main post)
Erik |
Posted: Thu May 08, 2008 7:21 pm |
| Quote: | #include <16f88.h>
#use i2c(MASTER,slow, SDA=PIN_b1, SCL=PIN_b4,force_sw) |
The 16F88 data sheet doesn't say that it will run at 25 MHz.
It says the limit is 20 MHz:
| Quote: |
• Three Crystal modes:
- LP, XT, HS: up to 20 MHz
• Two External RC modes
• One External Clock mode:
- ECIO: up to 20 MHz
erik006
| Re: |
Posted: Thu May 08, 2008 7:25 pm |
| Good point,but I just didn't have a 20 mhz available. I did try the internal oscillator, an 8mhz crystal & a 12mhz crystal which had the same result. |
rnielsen
Posted: Fri May 09, 2008 9:37 am |
It's possible you are having timing issues. The master might be sending commands faster than the slave can process them.
If you have an o-scope available, try setting an output as soon as the ISR is entered and then reset the output just before the ISR is exited. Monitor the I2C bus and this output and you will be able to see if commands are being sent too quickly. It's possible that you need to add delays to allow the slave time to do it's thing.
Ronald
Never take a sleeping pill and a laxitive at the same time. |
erik006
| Re: |
Posted: Mon May 12, 2008 12:53 pm |
Mielsen, that's very possible, as the slave is using an internal osc (8Mhz), while the master was running at 12Mhz or more. Here are several things I tried.
-Using the 16F88 as the slave, everything is fine & works. This implies the master code is fine.
-Using another 18f2431 does not work.
-When I use a 20Mhz crystal as the clock source, using i2c_poll() seems to work, however, no interrupt occurs.
Thanks for your help so far!
Erik |
