desertkids
| timeout help |
Posted: Sun Dec 14, 2008 10:34 am |
why my timeout not function?can help me check my code?i need 2 timeout in my program, the first if not receive char's' in 1 minute then start the program. the second is when cant get the gps signal in 1seconds then jump out from the loop. i use PCH compiler v4.032.
#define (__PCH__)
//==================include=================================
#include <18F4550.h>
#fuses HS,WDT,NOPROTECT,NOLVP
#device ADC=10 // define 10 bit resolution
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, parity=n, bits=8, BRGH1OK, stream=UART)
#use rs232(baud=4800, xmit=PIN_D0, rcv=PIN_D1, parity=n, bits=8, BRGH1OK, stream=GPS)
#include <stdlib.h>
#include <input.c>
//===============define IO port=============================
#define sw1 pin_b0
#define temp1_ch 0
#define temp2_ch 1
#define press_ch 4
#define acc_x_ch 5
#define acc_y_ch 6
#define acc_z_ch 7
//=====================variable==========================
int temp_1[40],temp_2[40];
float press[40],acc_x[40],acc_y[40],acc_z[40];
float volt_temp_1,volt_temp_2,volt_press,volt_acc_x,volt_acc_y,volt_acc_z;
int n=0,i=0,k=0;
long timeout;
int1 good_fix;
int len;
char gps_str[60],temp_str[8];
int8 count=0,rcv_chr;
float alt_float[40],lat_float[40],log_float[40];
float utc_float;
unsigned int sat=0;
short timeout_error;
char length[120];
char f1[10]= "*DR=03s/R";
char str_in[10];
int ini=24,wait=26,sta=7,sen=14,c=0,com1_result;
//==============FUNCTION PTOTOTYPE=========================
float analog_read(int channel);
void get_fix();
//=================MAIN PROGRAM================================
set_tris_a(0xff); // Let all port A analog channel become input
setup_adc_ports(AN0_TO_AN7); // All port A is used as analog
setup_adc(ADC_CLOCK_DIV_64); // Fosc/Fsam => 20000000/625 000 = 32 => 32
delay_ms(10);
fprintf(UART,"@DT%Xinitialization done.../R\r\n",ini);
fprintf(UART,"@DT%Xwait for start signal.../R\r\n",wait);//wait for start signal,char 's'
delay_ms(10);
timeout=0;
do{
rcv_chr=fgetc(UART);
}while(rcv_chr!='s'&&(++timeout<10000));
fprintf(UART,"@DT%Xstart/R\r\n",sta);
for(n=0;n<40;n++)
i++;
volt_temp_1= analog_read(temp1_ch);
temp_1[n]=((float)volt_temp_1-2.73)*100;
volt_temp_2= analog_read(temp2_ch);
temp_2[n]=((float)volt_temp_2-2.73)*100;
volt_press=analog_read(press_ch);
press[n]=(((float)volt_press-0.204)*21.7865)+15;
volt_acc_x= analog_read(acc_x_ch);
acc_x[n]=(((float)volt_acc_x-1.5)/0.3);
volt_acc_y= analog_read(acc_y_ch);
acc_y[n]=(((float)volt_acc_y-1.5)/0.3);
volt_acc_z= analog_read(acc_z_ch);
acc_z[n]=(((float)volt_acc_z-1.5)/0.3);
good_fix=false;
get_fix();
sprintf(length,",%2d,%1.2f,%1.1f,%1.2f,%1.1f,%1.2f,%1.1f,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d,%6.0f,%4.2f,%5.2f,%3.1f,%2d/R",i,volt_acc_x,acc_x[n],volt_acc_y,acc_y[n],volt_acc_z,acc_z[n],volt_press,press[n],volt_temp_1,temp_1[n],volt_temp_2,temp_2[n],utc_float,lat_float[n],log_float[n],alt_float[n],sat);
len = strlen(length);
fprintf(UART,"@DT%X,%2d,%1.2f,%1.1f,%1.2f,%1.1f,%1.2f,%1.1f,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d,%6.0f,%4.2f,%5.2f,%3.1f,%2d/R\r\n",len,i,volt_acc_x,acc_x[n],volt_acc_y,acc_y[n],volt_acc_z,acc_z[n],volt_press,press[n],volt_temp_1,temp_1[n],volt_temp_2,temp_2[n],utc_float,lat_float[n],log_float[n],alt_float[n],sat);
delay_ms(1500);
fprintf(UART,"@DT%Xwait for 'r'/R\r\n",sen);
do {
}while(rcv_chr!='r');
for(n=0;n<40;n++)
k++;
fprintf(UART,"\r\nN=%d,TEMP_1=%d,TEMP_2=%d,PRESS=%3.2f,ACC_X=%1.1f,ACC_Y=%1.1f,ACC_Z=%1.1f,LAT=%4.2f,LONG=%5.2f,ALT=%3.1f",k,temp_1[n],temp_2[n],press[n],acc_x[n],acc_y[n],acc_z[n],lat_float[n],log_float[n],alt_float[n]);
delay_ms(10);
fprintf(UART,"\r\nFINISH ALL!!!");
delay_ms(10);
//===============SUBROUTINE ADC=====================
float analog_read(int channel){
float tmp = 0;
float tmp_adc = 0;
int l=0;
set_adc_channel(channel);
delay_ms(10);
for(l=0;l<10;l++)
tmp_adc = read_adc();
tmp+=tmp_adc;
return (float)tmp/2046;
//===================SUBROUTINE GPS=============================
void get_fix(){
timeout=0;
while (!good_fix&&(++timeout<10000)){
rcv_chr=fgetc(GPS);
if (rcv_chr=='$'){
rcv_chr=fgetc(GPS);
if (rcv_chr=='G'){
rcv_chr=fgetc(GPS);
if (rcv_chr=='P'){
rcv_chr=fgetc(GPS);
if (rcv_chr=='G'){
rcv_chr=fgetc(GPS);
if (rcv_chr=='G'){
rcv_chr=fgetc(GPS);
if (rcv_chr=='A'){
rcv_chr=fgetc(GPS);
if (rcv_chr==','){
for (count=0;count<60;count++){
gps_str[count]=fgetc(GPS);
for (count=0;count<6;count++){
temp_str[count]=gps_str[count];
utc_float=atof(temp_str);
for (count=0;count<7;count++){
temp_str[count]=gps_str[7+count];
lat_float[n]=atof(temp_str);
for (count=0;count<8;count++){
temp_str[count]=gps_str[19+count];
log_float[n]=atof(temp_str);
for (count=0;count<3;count++){
temp_str[count]=gps_str[34+count];
sat=atoi(temp_str);
temp_str[count]=gps_str[42+count];
alt_float[n]=atof(temp_str);
good_fix=true;
