Tom_HUN Guest
| Interrupt termination |
Posted: Mon Mar 24, 2008 1:22 am |
Hi!
Is it possible, to terminate an interrupt routine? I mean, I want to forget about the PCLATH and go to a completely different place, from where the ISR routine was called. I'm running a menu on the LCS screen. There are sub-functions, reachable by pushing buttons. The EXT interrupt is caused by one button (16F877 - B0). I want the isr to go back to the menu function. I can not do by calling it, because then it will run inside the isr (not running - using too much PCLATH). So, what is the solution?
Menu function:
| Code: | void Menu()
output_low(PIN_B5);
output_low(PIN_B4);
output_low(PIN_B3);
lcd_putc("\f Tesztpanel\n");
lcd_putc("1:INT 2:ADC 3:LED");
if (!input(PIN_B1))
ADC();
if (!input(PIN_B2))
LED();
ISR:
#int_EXT
void ISR()
What to do to terminate everything, and go to the menu funct? Except reset_cpu().  |
Posted: Mon Mar 24, 2008 3:10 am |
Write your main code, so it tests a flag, and calls the menu if this is set. Set the flag in the ISR.
Do a search here, a lot of examples have been posted in the past.
Tom_HUN Guest
Posted: Mon Mar 24, 2008 3:36 am |
| Ttelmah wrote: | Write your main code, so it tests a flag, and calls the menu if this is set. Set the flag in the ISR.
Thanks fot the idea! It's working like charm!
All the very best from Hungary! |
