Can not start target PIC16F690
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Mar 13, 2008 5:44 pm     Reply with quote
Colleagues,
I can't start my PIC16F690. I'm getting the following message: "Could not start target: The target was not halted after reset. Check target oscillator and MCLR. Make sure the target clock match the clock fuse and that the target is oscillating. Use View | Valid fuses to find the correct clock fuse."
I've checked the hardware. Vcc is +3.3V. MCLR is pulled up to Vcc and it exibits normal behavior during programming. My external oscillator is oscillating (12.288MHz), and it's connected to pin 2.
Here are the fuses:
#include <16F690.h>
#device ICD=TRUE
#device adc=8
#FUSES EC_IO //External clock
Here's the description if my development environment:
- PCWH 3.240 (it's relatively old, but it has an entry for 16F690 and an .h file for it)
- ICD firmware V 1.39
- ICD control program V 2.87
What do you think could be causing my problem?
Thanks,
Nick
Read the label, before opening a can of worms.
PostPosted: Thu Mar 13, 2008 6:21 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=25342
Even if you had a modern version of the compiler, and the special -ICD
version of the chip, CCS still doesn't support debugging that PIC at
+3.3v. See the entry for 16F690 on this page:
http://www.ccsinfo.com/devices.php?page=icddevices
ECACE
PostPosted: Fri Mar 14, 2008 7:38 am     Reply with quote
Take a look at the datasheet for the 16F690...that part does not have a debug module in it. You can serial program it, but that's it.
Here is a clip from the 16F872 datasheet. Notice the third point:
• In-Circuit Serial Programming™ (ICSP™) via two
pins
• Single 5V In-Circuit Serial Programming capability
• In-Circuit Debugging via two pins
Now from the 16F690:
• In-Circuit Serial ProgrammingTM (ICSPTM) via two
pins
Also can be seen in the special features section of the datasheets.
You need to use a smarter PIC if you want the debug function. That chip just recently got me too. I figured that one out after I had already designed it in.
A HW Engineer 'trying' to do SW !!! Run!!!
Trent___
PostPosted: Fri Mar 14, 2008 12:05 pm     Reply with quote
I fell for it aswell.
The dev board Microchip have which offer's the Debug has some strange behaviour's too.
If you can use something else with debug ability do it.
