smiles
| atoi function |
Posted: Fri Feb 22, 2008 9:00 am |
My task is press button to select time for relay on and off, but it doesn't work now, here is my code, hope you show me where I am wrong (my LCD works well as I expect, I think the problem lie in my C coding)
int array[16]={'1','4','7','<','2','5','8','0','3','6','9','>','C','&','E','M'};
int keyPressed;
int16 timeResult;
// declare functions ...
// TODO: USER CODE!!
InitPic();
InitLcd();
timeResult=Keypad();
do
output_high(PIN_C0);
delay_ms(timeResult);
output_low(PIN_C0);
int OnRelease()
int i,j,k;
int value[4]={0x07,0x0B,0x0D,0x0E};
set_tris_a(0x0f);
k=0;
for(i=0;i<4;i++)
output_d(value[i]);
delay_us(100);
for(j=0;j<4;j++)
if(!input(40+j))
do
delay_ms(50);
while(!input(40+j));
return k;
k++;
return -1;
int16 Keypad()
char number[];
int iNum;
int16 numResult;
timeResult=0;
do
keyPressed=OnRelease();
if ((array[keyPressed] > 0x2F) && (array[keyPressed] < 0x3A)) // for numbers 0-9 only
WrDat2Lcd(array[keyPressed]);
number[iNum]=array[keyPressed];
iNum++;
if (array[keyPressed] == 'E') // press Enter key to exit function
number[iNum]='\0';
numResult=atoi(number);
return numResult;
Thanks !!! |
SET
Posted: Fri Feb 22, 2008 1:57 pm |
| Quote: | | Code: | int OnRelease()
int i,j,k;
set_tris_a(0x0f);
k=0;
for(i=0;i<4;i++)
output_d(value[i]);
delay_us(100);
for(j=0;j<4;j++)
if(!input(40+j))
do
delay_ms(50);
return k;
k++;
return -1; // << signed return value!
Remember ints are unsigned in CCS so this function may not work as you expect it to..
Also..
| Quote: | | Code: | int16 Keypad()
char number[]; |
You need to set a size for 'number'
And Ive just noticed that you dont initialise inum |
