SPI Pic to Pic Problem (Master can't read Slave)
temopic
PostPosted: Wed Feb 20, 2008 12:59 pm     Reply with quote
this is an app SMMS (Single Master-Multiple Slave) (one Master and 6 Slaves) All Pic18f2520.
I succesfully communicate the PC RS-232-to-Master and Master-to-Slave
But need help to communicate the Slave-to-Master. I cant make the Master to read from the Slave
=========Master========================
//Master Main Program
#include <18F2520.h>
#include <USART1.c>
#include <SPIMASTER.c>
#include <portinimaster.c>
#BYTE sbuffer = 0xFc9
#include <string.h>
#use delay(clock=20000000)
int b=0;
char data;
char a;
char z;
port_initialize();
enable_interrupts(global);
enable_interrupts(int_rda);
enable_interrupts(INT_SSP);
delay_ms(255);
output_low(pin_c2); //test led On
output_high(pin_c2); //test led Off
do {
a=bgetc();
bputc("\n\r");
bputc(a);
spi_write(a);
delay_ms(20);
z=spi_read(0)
bputc(z); //Print "z" in Hyperterminal
z=spi_read(0)
bputc(z);
z=spi_read(0)
bputc(z);
z=spi_read(0)
bputc(z);
void port_initialize(){
set_tris_b(0b00000101);
set_tris_c(0b10010011);
set_tris_a(0b10100000);
//setup_spi(spi_slave | spi_H_to_l | spi_clk_div_16);
setup_spi(spi_master | spi_l_to_h | spi_clk_div_16);
//SPI Master
char c;
char mensaje[8] = {0x30,0x31,0x32,0x33,0x34,0x35,0x36};
#int_SSP
void SPIMANGER() {
=========SLAVE========================
#include <USART1.c>
#include <SPISLAVE.c>
#include <portinislave.c>
#include <string.h>
int b=0;
char data;
char a;
byte d;
d =0x41;
port_initialize();
do {
delay_ms(50);
delay_ms(50);
a=bgetc();
bputc("\n\r");
bputc(a); //Print "a" in the Hyperterminal
}//end main
char c;
int8 index;
int8 SPIData;
long i=0;
char mensaje[30] = {""};
#int_SSP
void SPIMANGER() {
if( spi_data_is_in() )
c = spi_read();
bputc(c); //Print "c" in the hyperterminal
//spi_write(c);
output_low(pin_b7);
output_high(pin_c0);
set_tris_b(0x20); //make port b all outputs
set_tris_D(0x40); // make d7 input all other output
What I am doing wrong?
I am working with PCWH compiler
ide version 3.212
pcb 3.212
pcm 3.212
pcm 3.212
PostPosted: Wed Feb 20, 2008 1:29 pm     Reply with quote
1. Get rid of 90% of your code and write small test programs for both
master and slave.
2. Don't try to make it work with multiple slaves. Just make it work
with one slave for this first test.
3. Don't set the TRIS. Use standard i/o mode and let the compiler
do it for you automatically. (Standard i/o is the default mode of the
compiler. You don't have to do anything to enable it).
4. Look at the CCS example code for an SPI slave.
c:\program files\picc\examples\ex_spi_slave.c
Look at other examples in the forum archives:
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
temopic
PostPosted: Wed Feb 20, 2008 5:42 pm     Reply with quote
=======Master Code===========
#include <USART1.c>
#include <string.h>
char a;
char b;
int i=0;
delay_ms(300);
output_low(pin_b7);                       //test pin 2
output_low(pin_b6);                       //test pin 1
output_low(pin_b5);
output_low(pin_b4);
output_low(pin_a3);
output_low(pin_a2);
output_low(pin_a1);
output_low(pin_a0);
bputc("\n\r");
printf("Hello World");
bputc("\n\r");
do {
delay_ms(50);
   a=bgetc();
         bputc("\n\r");
printf("%C  escribiste", a);
spi_write(a);  // or whatever
delay_ms(50);
for (i=0; i<8; ++i)
b=spi_read(0);
bputc(b);
bputc("\n\r");
delay_ms(50);
}//end main
#int_SSP
void SPIMANGER() {
===================Slave1 Code=============
#include <USART1.c>
#include <string.h>
char a;
set_tris_c(0b10011011);
setup_spi(spi_slave | spi_L_to_H);
output_low(pin_b5);
output_low(pin_b4);
output_low(pin_a3);
output_low(pin_a2);
output_low(pin_a1);
output_low(pin_a0);
output_low(pin_c2);
printf(bputc, "Se escribira lo que recibes por SPI");
do {
   a=bgetc();
         bputc("\n\r");
         bputc(a);
  while (1);
}//end main
char c;
#int_SSP
void SPIMANGER() {
   c = spi_read();
   bputc(c);
   spi_write(c);
   spi_write(c+1);
   spi_write(c+2);
   spi_write(c+3);
   spi_write(c+4);
   spi_write(c+5);
   spi_write(c+6);
   spi_write(c+7);
Thank you PCM programmer
your recommendations 1 and 2 fixed my problem
One more question:
Have somebody implement some kind of handshake-protocol-crc for SingleMaster-MultipleSlaves?
