		| Author | Message |
		| ruijing2
				| how to use PWM and CCP_CAPTURE_FE ? |
				|  Posted: Wed Apr 30, 2008 4:04 am |   |
				| hi can u help me? i use ccs c and PIC18F452.
 i want to use PWM and CCP_CAPTURE_FE.
 Try it but when i on PWM and CCP_CARTURE_FE TOGETHER as ccp1 and ccp2. The PWM(ccp2) did something to the CCP_CARTURE_FE(ccp1) interrupt.
  	  | Code: |  	  | #elif defined(__PCH__)
 #include <18F452.h>
 #device ICD=true
 #fuses HS,NOWDT,NOLVP,WDT128,NOPUT,NOBROWNOUT,NOPROTECT,NOWRTD,CPD
 #use rs232(parity=N,BITS=8,xmit=PIN_C6,rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
 int32 en=0;
 int32 countstore=0,countstore2=0;
 unsigned int32 count=0,duty=128;
 int32 ans=0,ans3=0,ans2=0;
 int32 in=0,count2=0;
 #INT_TIMER1
 void time1()
 // for(;;)
 count++;
 #INT_CCP1
 void hahah()
 //      if(count2>=1 && count2 <17 )
 countstore2=CCP_1;
 countstore=count;
 count=0;
 //else if(count2==0)
 //    en=CCP_1;
 //    count2++;
 //    count=0;
 ans3=((countstore*65536)+countstore2)-en;
 //       printf("en=%lu \r\n ",en);
 //      printf("countstore2=%lu \r\n ",countstore2);
 //       printf("countstore=%lu \r\n ",countstore);
 //      printf("count2=%lu \r\n ",count2);
 //      printf("ans=%lu \r\n ",ans);
 countstore=0;
 in=0;
 if(en!=countstore2)
 en=countstore2;
 // count2++;
 // count=0;
 if(count2!=0)
 ans2+=ans3;
 count2++;
 if(count2==17)
 ans=ans2/(count2-1);
 //       printf("count2=%lu \r\n ",count2-1);
 //       countstore=0;
 count2=0;
 //       countstore2=0;
 in=0;
 ans2=0;
 //     countstore2=CCP_1;
 //     countstore=count;
 set_uart_speed(9600);
 setup_ccp1(CCP_CAPTURE_FE);
 setup_ccp2(CCP_PWM);
 setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
 setup_timer_2 ( T2_DIV_BY_1, 255, 1);
 enable_interrupts(INT_CCP1);
 for(;;)
 if(in==0)
 if(ans>10000001 && duty >0)
 duty--;
 }else if(ans<9999999 && duty <128)
 duty++;
 in=1;
 set_pwm2_duty(10L);
		| Matro Guest
				|  Posted: Wed Apr 30, 2008 4:16 am |   |
				| Please post a small clean compilable code that demonstrates the problem and try to provide a deeper explanation of the issue you are encountering.
 Matro
		| ruijing2
				|  Posted: Wed Apr 30, 2008 4:22 am |   |
				| #INT_TIMER1 void time1()
 #INT_CCP1
 void hahah()
 for(;;)
 set_pwm2_duty(10L);
		| ruijing2
				| re: |
				|  Posted: Wed Apr 30, 2008 4:34 am |   |
				| it keep interrupt the ccp1 as it will interrupt at 1s only |  |
		| Matro Guest
				|  Posted: Wed Apr 30, 2008 5:16 am |   |
				| I definitely don't understand what is the "problem".
 What is your hardware?
 What are you trying to do?
 What did you expect?
 What do you really obtain?
 Matro
		| ruijing2
				|  Posted: Wed Apr 30, 2008 5:47 am |   |
				| i want to use EXTERNAL 1pps to read 10M count from EXTERNAL 10MHz clock. And to control the PWM. |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
