		| Author | Message |
		| robotam
				| i2C_Stream |
				|  Posted: Wed Feb 13, 2008 3:36 pm |   |
				| Hello
 Someone could post a example code of i2c communication using "Stream".
 thanks
		| rnielsen
				|  Posted: Thu Feb 14, 2008 9:52 am |   |
				| As far as I know, STREAM is only available with the RS232, not the I2C.
 Ronald
		| PCM programmer
				|  Posted: Thu Feb 14, 2008 11:43 am |   |
				| Streams can be specified in the #use i2c() statement in vs. 4 of the compiler.  See the current manual:
 http://www.ccsinfo.com/downloads/CReferenceManual.pdf
 To answer the question, specify the name of the stream in the #use i2c()
 statement.    Do this in the same way as a stream is specified in a
 #use rs232() statement.    Then, in every i2c function, specify the stream
 that you're using.
 Instead of doing this:
 You would do  this:
  	  | Quote: |  	  | i2c_write (stream, data); |
 All the rest of the i2c functions must also have a stream parameter
 (if you are using streams).  Example:
  	  | Code: |  	  | i2c_poll(stream);
 data = i2c_read(stream);
 data = i2c_read(stream, ack);
 i2c_start(stream);
 i2c_start(stream, restart);
 i2c_stop(stream);
