ahmad-al3omar
| width between two pulses |
Posted: Wed Feb 13, 2008 3:19 am |
hello all;
i am trying to calculate the time difference between two pulse waves , i am using the the pic18f458 and i connect each pulse wave to interrupt 0 and interrupt 1 and i use timer1 to calculate the time between two edges
i am using the following code :
| Code: | #include<18f458.h>
#fuses noprotect,nowdt,xt
#include<lcd.c>
int value;
#int_ext
ext1_isr()
set_timer1(0);
#int_ext1
ext2_isr()
value=get_timer1();
lcd_gotoxy(1,2);
printf(lcd_putc,"value= %d ",value);
main()
lcd_init();
enable_interrupts(global);
enable_interrupts(int_ext1);
enable_interrupts(int_ext2);
setup_timer_1(t1_internal|t1_div_by_8);
ext_int_edge( l_TO_h);
ext_int_edge( 1, l_TO_h);
lcd_gotoxy(1,1);
but the output value on the lcd is changed rapidly and not constant on the simulation .
can you help me to find out the way to calculate the difference ???
thank you all _________________ A.T.N |
kolio
Posted: Wed Feb 13, 2008 2:24 pm |
Hi Ahmad,
Don't use lcd_gotoxy() and printf() in ISR. Read about "re-entrant code".
Try this one:
#include<18f458.h>
#include<lcd.c>
int value;
int1 Completed;
#int_ext
ext1_isr()
if(!Completed) set_timer1(0);
#int_ext1
ext2_isr()
value=get_timer1();
Completed = 1;
//lcd_gotoxy(1,2);
//printf(lcd_putc,"value= %d ",value);
main()
lcd_init();
Completed = 0;
if(Completed){
lcd_gotoxy(1,1);
Completed = 0;
In this way you may miss some pulses during printing the result on LCD, but the measurement will be properly displayed. Also pay attention about the duration and edges of the pulses. |
