Preserving a variable during reset
dwburlington
PostPosted: Fri Feb 08, 2008 10:27 am     Reply with quote
is there a way to tell the compiler not to initialize a variable to 0 during a reset.??
PostPosted: Fri Feb 08, 2008 10:38 am     Reply with quote
Anything that is not static/global, and is not assigned a value, is not by default initialised. So a simple variable declared inside the main as:
int8 fred;
Will retain the value it last had (but will also contain garbage on the first boot).
Remember though that variables in _subroutines_, can have the memory storage area re-used, so it has to be declared in main.
You can also use #locate, to put a variable into an area of memory, that _you_initialise on the first 'real' boot, but leave unchanged on resets.
dwburlington
PostPosted: Fri Feb 08, 2008 10:45 am     Reply with quote
perfect that will work.
asmallri
PostPosted: Fri Feb 08, 2008 11:43 am     Reply with quote
Naturally the situation changes if you are using a bootloader as the bootloader has no visibility in the the memory space used by the application.
Regards, Andrew
