Dallas DS18s20 driver
omallicha
PostPosted: Thu Feb 07, 2008 4:48 am     Reply with quote
this is a working driver for the DS18s20 temperature sensor.
* Driver for Maxim DS18S20
* Version 2.0
* Date: 30/05/2007
* Using CCS C Compiler
// Define the data pins from microcontroler
//#define ds18s20_dq_sensor1   PIN_c1
// ROM Commands
#define DS18S20_READ_ROM   0x33
#define DS18S20_MATCH_ROM   0x55
#define DS18S20_SKIP_ROM   0xCC
// Function Commands
#define DS18S20_CONVERT_T   0x44
#define DS18S20_READ_SCRATCHPAD   0xBE
// For memorize the CRC value
int ds18s20_crc;
// Actualize ds18s20_crc after insert a bit
void ds18s20_actualizeCRCbit(int1 valueBit)
   int1 xor_crcBeforeBit0_Input;
   byte crcBefore;
   crcBefore = ds18s20_crc;
   // Calculation xor_crcBeforeBit0_Input
   if ((crcBefore & 0x01) == valueBit) xor_crcBeforeBit0_Input = 0;
   else   xor_crcBeforeBit0_Input = 1;
   // Calculation crcBit0
   if ((crcBefore & 0x02) > 0) ds18s20_crc |= 0x01;
   else   ds18s20_crc &= 0xFE;
   // Calculation crcBit1
   if ((crcBefore & 0x04) > 0) ds18s20_crc |= 0x02;
   else   ds18s20_crc &= 0xFD;
   // Calculation crcBit2
   if ((crcBefore & 0x08) > 0)
      if (xor_crcBeforeBit0_Input == 0) ds18s20_crc |= 0x04;
      else   ds18s20_crc &= 0xFB;
      if (xor_crcBeforeBit0_Input == 1) ds18s20_crc |= 0x04;
   // Calculation crcBit3
   if ((crcBefore & 0x10) > 0)
      if (xor_crcBeforeBit0_Input == 0) ds18s20_crc |= 0x08;
      else   ds18s20_crc &= 0xF7;
      if (xor_crcBeforeBit0_Input == 1) ds18s20_crc |= 0x08;
   // Calculation crcBit4
   if ((crcBefore & 0x20) > 0) ds18s20_crc |= 0x10;
   else   ds18s20_crc &= 0xEF;
   // Calculation crcBit5
   if ((crcBefore & 0x40) > 0) ds18s20_crc |= 0x20;
   else   ds18s20_crc &= 0xDF;
   // Calculation crcBit6
   if ((crcBefore & 0x80) > 0) ds18s20_crc |= 0x40;
   else   ds18s20_crc &= 0xBF;
   // Calculation crcBit7
   if (xor_crcBeforeBit0_Input == 1) ds18s20_crc |= 0x80;
   else   ds18s20_crc &= 0x7F;
// Inicialize the line
// Returns 0 if exists one or more sensors in the line
int1 ds18s20_inicializeLine()
   int1 ack;
   ack = 0;
   output_float(ds18s20_dq_sensor1);
   delay_ms(1);
         output_bit(ds18s20_dq_sensor1, 0);
         delay_us(600);
         delay_us(100);
         ack = input(ds18s20_dq_sensor1);
         delay_us(500);
   return (ack);
// Write bit in the line
void ds18s20_writeBit(int1 valueBit)
   if (valueBit == 0)
            delay_us(110);
            delay_us(100);
            delay_us(10);
            delay_us(200);
// Read bit in the line
int1 ds18s20_readBit()
   int1 readBit;
         delay_us(5);
         delay_us(15);
         readBit = input(ds18s20_dq_sensor1);
         delay_us(100);
   ds18s20_actualizeCRCbit(readBit);   // Actualize CRC
   return(readBit);
// Write byte in the line
void ds18s20_writeByte(int8 valueByte)
   int i,mask;
   mask = 0x01;
   for (i=0; i<8; i++)
      if((valueByte & mask) > 0)  ds18s20_writeBit(1);
      else ds18s20_writeBit(0);
      mask = mask << 1;
// Read byte in the line
int8 ds18s20_readByte()
   int8 i,valueByte = 0;
   const int8 mask0 = 0x00;
   const int8 mask1 = 0x80;
   for (i=0; i<8; i++)
      valueByte = valueByte >> 1;
      if (ds18s20_readBit() == 1) valueByte |= mask1;
       else valueByte |= mask0;
   return (valueByte);
// Sends the command Read Scratchpad
int1 ds18s20_sendsCommandReadScratchpad()
   int1 ack;
   ack = ds18s20_inicializeLine();
   if (ack == 1)
      return (1);
   ds18s20_writeByte(DS18S20_SKIP_ROM);
   ds18s20_writeByte(DS18S20_READ_SCRATCHPAD);
   return (0);
// Reads the value of temperature (resolution 1şC)
int8 ds18s20_readTemperatureLowResolution()
   int8 valueTemperature;
   if (ds18s20_sendsCommandReadScratchpad() == 1)
      return (100);
   ds18s20_crc = 0;
   valueTemperature = ds18s20_readByte()/2;
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   // Error on value read
   if (ds18s20_crc != 0)
      return (100);
   return (valueTemperature);
// Reads the value of temperature (resolution 0.1şC)
int16 ds18s20_readTemperatureHighResolution()
   float temperature,aux;
   int8 temp_read, count_per_c, count_remain;
      return (0);
   ds18s20_crc = 0;
   temp_read = ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   ds18s20_readByte();
   count_remain = ds18s20_readByte();
   count_per_c = ds18s20_readByte();
   ds18s20_readByte();
      return (0);
   temp_read = temp_read >> 1;
   temp_read &= 0x7F;
   temperature = temp_read - 0.25;
   aux = count_per_c - count_remain;
   aux /= count_per_c;
   temperature += aux;
   temperature *= 10;
   return (temperature);
// Send a command ConvertT for one sensor
// Need to wait for about one second before read the value
int1 ds18s20_startConvert()
   int1 ack;
   if (ack == 1)
      return (1);
   ds18s20_writeByte(DS18S20_CONVERT_T);
   return (0);
Poun44
PostPosted: Tue Feb 12, 2008 2:24 am     Reply with quote
Does it works with a PIC16F877 ?
Because it doesn't work, Can you help me?
