Variable Declaration - Position Dependant? - SOLVED
Seijling
View user's profile Send private message MSN Messenger ICQ Number
PostPosted: Wed Feb 06, 2008 10:47 pm     Reply with quote
This may appear the most newb question possible but: can one declare variables at any point in TODO code?
i.e.
char *MakeString(char string[])
   int len;
   len = strlen(string);
   char temp[len]; //this declaration
The reason I ask is because if I try this "maneuver" I get the error message:
A numeric expression must appear here
which points to the line where the char is declared.
You can see why I am declaring it later in the code since work must be done first to obtain the char array's length.
Any thoughts would be appreciated.
Michael K
compiler 4.038
device 16F877A
PostPosted: Wed Feb 06, 2008 11:01 pm     Reply with quote
CCS C is like 'Small C' it is not C++. From a C manual I found on the web,
Local variables
Local variables must always be defined at the top of a block.
You must allocate the max length of the string - later you can pass pointers around.
HTH - Steve H.
Seijling
PostPosted: Wed Feb 06, 2008 11:14 pm     Reply with quote
There lies the rub - the length of the string will be variable.
I know I could just pick an upper limit on the length for the string. The problem is that I will pass the string (and only the string) to a function which "pastes" it into a buffer which is a predefined 40 chars wide.
Once the data has been placed, I send the buffer -and yes, the premise for doing this is for an LCD application.
The function for doing this is:
void MakeBuffer (char *string, int LocX, int LocY)
   int i;
   switch (LocY)
      case 1:
         for(i=0;i<strlen(string);i++) Line1[LocX+i-1] = string[i];
      case 2:
         for(i=0;i<strlen(string);i++) Line2[LocX+i-1] = string[i];
      default:
         errorLED();
You can see that if I pass a string that is padded with more than the required data, I may overwrite buffer data.
Something tells me I am doing this in the most complicated way possible. Rolling Eyes
Michael K
Compiler 4.038
Device 16F877A
Seijling
PostPosted: Thu Feb 07, 2008 12:13 am     Reply with quote
Hey! What do you know? I actually found something on the CCS webby that covers this:
http://www.ccsinfo.com/content.php?page=flexconst
Very useful and informative (as always). Way to go CCS. Very Happy
The solution was basically this:
#device PASS_STRINGS=IN_RAM
Michael
Wayne_
PostPosted: Thu Feb 07, 2008 6:14 am     Reply with quote
To do what you want in your first post you need to either have a MAX string size or dynamically allocate and DO NOT FORGET to de-allocate memory:-
void myfun(char *string, len) {
  char *buf;
  buf = malloc(len + 1); // Enough space for the null terminating char
  strcpy(buf, string);
  // do something with buf
  free(buf); // If you DON'T do this you could eat up memory. This can be done elsewhere in your code.
BUT to do what you are doing with the buffer you just need some protection :-
   int i;
   switch (LocY)
      case 1:
         for(i=0;i<strlen(string);i++) {
           if (LocX + i >= 40)
      case 2:
            if (LocX + i >= 40)
      default:
         errorLED();
Neutone
PostPosted: Thu Feb 07, 2008 12:28 pm     Reply with quote
Michael K
Compiler 4.038
Device 16F877A
#include <string.h>
   Int8 LCD_buffer1[41];
   Int8 LCD_buffer2[41];
{  strcpy (LCD_buffer1[4], "Hi There");
   strcpy (LCD_buffer1[0], "Hi There");
This may be a better way for you to get what you want. Simply include the index to place the text where you want it to go. This is also easy to read.
luckylucker
great topic
PostPosted: Thu Mar 13, 2008 3:09 am     Reply with quote
Great topic )))))))))))))
WBR,
Alex
