		| Author | Message |
		| bwhiten
				| "Stop" Timers question |
				|  Posted: Mon Feb 04, 2008 1:26 pm |   |
				| I am looking at a Microchip code sample that mentions the next step in an ISR as "StopTimers();".  No further description of the function is given of course, so my question is, would disabling a timer be the same as stopping one and can the last timer value still be read after disabling? I'm using a 16F887 PIC. |  |
		| PCM programmer
				|  Posted: Mon Feb 04, 2008 1:50 pm |   |
				| Post the appnote number and post a link to it. |  |
		| bwhiten
		| PCM programmer
				|  Posted: Mon Feb 04, 2008 2:37 pm |   |
				| The short answer is:
 You can stop Timer1 by setting the TMR1ON bit = 0 in the T1CON register.
 Example:
  	  | Code: |  	  | #byte T1CON = 0x10
 #bit TMR1ON = T1CON.0
 TMR1ON = 0;   // Turn Timer1 off
 TMR1ON = 1;   // Turn Timer1 On
 Timer0 doesn't have an on/off bit.
 To really solve your problem I'd have to read the whole appnote, and
 I don't want to do that right now.
		| bwhiten
				|  Posted: Mon Feb 04, 2008 9:11 pm |   |
				| Really not a problem, just clarification. I did test and disabling does not clear the count so it accomplishes my purpose. I like using your bit method better because it is clearer to me what I am accomplishing, rather than the T1_DISABLE control for SETUP_TIMER_1() function. |  |
