Int_RA
SerialGmr8
Int_RA
PostPosted: Thu Jan 31, 2008 1:50 pm     Reply with quote
Hello all,
I've been trying to use the interrupt on change on the port A pins, but the compiler states that it doesnt recognise "#define int_ra".
Im using PCW Compiler versions 4.057.
my code is as follows:
 #include <16F877A.h>
int8 value = 0;
#INT_RA
void portchange_isr ()
 value= input(PIN_A0);
   output_low(pin_c5);
   enable_interrupts(INT_RA);
       if(value == 0)
             output_low(PIN_C5);
             output_high(PIN_C5);
I've used the same code as above for port b, except that I change int_ra to int_rb in both lines and it works fine...
can anyone please advise ?
PostPosted: Thu Jan 31, 2008 2:33 pm     Reply with quote
Look in the 16F877A.H file. There is a list of available interrupts at the
end of the file.
c:\Program Files\picc\Devices\16F877A.h
Download the 16F877A data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39582b.pdf
Look at this section, on page 43 in the Acrobat reader:
4.1 PORTA and the TRISA Register
Do you see any place where it says that Port A has interrupt-on-change ?
