12F510 frustrations
Ad01
12F510 frustrations
PostPosted: Thu Jan 24, 2008 4:03 pm     Reply with quote
Hi all,
I am trying to use a 12F510 to flash an LED once (PIN_B0 and PIN_B1) on start up before displaying Hello World to the computer terminal. Unfortunately these B0 and B1 pins never turn on no matter what I try (GP4 and GP5 do work) and the computer receives garbage characters. I have tried numerous modifications to the code below change baud rate, turn off AI comparators etc but cant seem to nail it can anyone help?
include <12F510.h>
#device adc=8
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
//#FUSES RB4                      //B4 is an I/O pin not CLKOUT
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B4,bits=8)
setup_comparator(NC_NC);
output_high(PIN_B0);
output_high(PIN_B1);
output_low(PIN_B0);
output_low(PIN_B1);
while(1){
     printf("Hello World");
PostPosted: Thu Jan 24, 2008 4:10 pm     Reply with quote
1. Post your compiler version.
2. Post your connections to the PC's Com port connector.
Do you have a MAX232-type chip in the circuit ?
Ad01
PostPosted: Thu Jan 24, 2008 4:19 pm     Reply with quote
My compiler version is 4.057.
The RS232 connection to my computer i have tested with other 12F, 16F chips with no problems.
PostPosted: Thu Jan 24, 2008 4:47 pm     Reply with quote
The GP0 and GP1 pins are used for ICSP programming. Do you have
a programmer connected to the 12F510 while you are running the printf()
and the LED tests ? If so, disconnect it.
Ad01
PostPosted: Thu Jan 24, 2008 5:07 pm     Reply with quote
No, I have one breadboard for programming and another for circuit applications, totally isolated from one another.
PostPosted: Thu Jan 24, 2008 5:37 pm     Reply with quote
In the 12F510, the internal oscillator frequency is set with a fuse
statement. If you don't specify it, the compiler defaults to 8 MHz.
That would explain why your RS-232 is garbled. Add this statement:
#FUSES IOSC4
Ad01
PostPosted: Thu Jan 24, 2008 5:50 pm     Reply with quote
Ok thanks PCM programmer ill give that a shot and let you know how I go.
mongkol
PostPosted: Fri Jul 12, 2013 7:09 am     Reply with quote
Before to used I/O port you have to turn off analog port with setup_adc_ports(NO_ANALOGS).
I'm MIKE
PostPosted: Fri Jul 12, 2013 2:33 pm     Reply with quote
Yes. Mongkol is right. The _chip_ defaults to waking up with the ports all set as analog. On later compilers, the compiler automatically fixes this, but on an old compiler like this, you need to turn the analog off to use the port for normal I/O.
