custom_elect
| SPI byte order inconsistent between software and hardware |
Posted: Sat Jan 19, 2008 6:19 pm |
Im just moving some working code from a software SPI:
#use spi (MASTER, DI=PIN_C4, DO=PIN_C5, CLK=PIN_C3, BITS=16)
to use the internal hardware SPI:
#use spi(SPI1, MASTER, BAUD=1000000, BITS=16)
I may be going loopy, but it looks like the byte order gets swapped.
In the software case, spi_xfer (0x800F) sends 0x80 then 0x0F as expected
In the hardware case, spi_xfer (0x800F) sends 0x0F then 0x80
Is this expected? or am I doing something wrong?
Any help greatly appreciated. |
Posted: Sat Jan 19, 2008 9:28 pm |
| Post the PIC and the compiler version. |
custom_elect
Posted: Wed Jan 23, 2008 12:11 pm |
The PIC is 16F877A
The compiler "CCS PCM C Compiler, Version 4.063, 41607"
The platform is "PICDEM 2 Plus" |
ECACE
Posted: Wed Jan 23, 2008 12:36 pm |
Have you tried playing with the LSB/MSB_First option of #use spi? I'm not sure if that is valid for HW and SW or just SW spi. It may be a case of by default the software spi did LSB first, and the HW spi sending MSB first or visa-versa. Not sure, but may be worth looking into. _________________ A HW Engineer 'trying' to do SW !!! Run!!! |
Posted: Wed Jan 23, 2008 1:36 pm |
I installed your compiler version. Here's the first test program, using
the hardware SPI module.
#include <16F877.H>
spi_xfer(0x800F);
From this portion of the .LST file, we can see that the upper byte
is put into 0x22, and the lower byte is put into 0x21.
....... spi_xfer(0x800F);
0038: MOVLW 80
0039: MOVWF 22
003A: MOVLW 0F
003B: MOVWF 21
003C: MOVLW 10
003D: MOVWF 23
003E: GOTO 004
// Here's the part where the bytes are sent. It shows that
// the lower byte is sent first. This is for the Hardware SPI
// method.
... #use spi(SPI1, MASTER, BAUD=1000000, BITS=16)
0004: MOVF 13,W
0005: MOVF 21,W // Get the lower byte (0x0F)
0006: MOVWF 13 // Put it in SSPBUF (transmit it)
0007: BSF 03.5
0008: BTFSS 14.0
0009: GOTO 008
000A: BCF 03.5
000B: MOVF 13,W
000C: MOVWF 78
000D: MOVF 22,W // Get the upper byte (0x80)
000E: MOVWF 13 // Put it in SSPBUF (transmit it)
000F: BSF 03.5
0010: BTFSS 14.0
0011: GOTO 010
0012: BCF 03.5
0013: MOVF 13,W
0014: MOVWF 79
0015: BCF 0A.3
0016: BCF 0A.4
0017: GOTO 03F (RETURN) |
Now let's make a 2nd test program that uses the software SPI method:
#include <16F877.H>
spi_xfer(0x800F);
Again, it puts the upper byte into 0x22, and the lower byte into 0x21.
This is for the software SPI.
| Code: | ... spi_xfer(0x800F);
004E: MOVLW 80
004F: MOVWF 22
0050: MOVLW 0F
0051: MOVWF 21
0052: MOVLW 10
0053: MOVWF 23
0054: GOTO 004
// This code for the software SPI, shows that it sends bit 0 of the
// lower byte first. All bits in the 16-bit word are shifted right and
// come out of Bit 0 of the lower byte.
| Code: | ... #use spi (MASTER, DI=PIN_C4, DO=PIN_C5, CLK=PIN_C3, BITS=16)
0004: BSF 20.4
0005: MOVF 20,W
0006: BSF 03.5
0007: MOVWF 07
0008: BCF 03.5
0009: BCF 20.5
000A: MOVF 20,W
000B: BSF 03.5
000C: MOVWF 07
000D: BCF 03.5
000E: BCF 20.3
000F: MOVF 20,W
0010: BSF 03.5
0011: MOVWF 07
0012: BCF 03.5
0013: BCF 07.3
0014: MOVF 23,W
0015: MOVWF 24
0016: BSF 07.3
0017: BTFSS 21.0 // Test bit 0 of the lower byte.
0018: BCF 07.5 // Set the DO pin based on the bit value.
0019: BTFSC 21.0
001A: BSF 07.5
001B: RRF 22,F // "Rotate right" the upper byte.
001C: RRF 21,F // Rotate it into the lower byte.
001D: BCF 07.3
001E: RRF 79,F
001F: RRF 78,F
0020: BTFSS 07.4
0021: BCF 79.7
0022: BTFSC 07.4
0023: BSF 79.7
0024: DECFSZ 24,F
0025: GOTO 016
0026: MOVF 23,W
0027: SUBLW 10
0028: BTFSC 03.2
0029: GOTO 02F
002A: MOVWF 24
002B: RRF 22,F
002C: RRF 21,F
002D: DECFSZ 24,F
002E: GOTO 02B
002F: BCF 0A.3
0030: BCF 0A.4
0031: GOTO 055 (RETURN) |
So, in each case, the lower byte (0x0F in your example) is shifted out
first. But the hardware SPI module shifts out the bits MSB first.
In other words, bit 7 of each byte is shifted out first. The software
module shifts out bit 0 first. That's what you're seeing.
In your original post you implied that some kind of byte swap is going on,
but that's not true. ECACE has a good solution. Add a parameter to
the software SPI declaration to change the bit order of transmission.
Then I believe you can make the two methods match each other.
If you do want to shift out Bit 0 first with the hardware SPI module,
this post has links to bit swapping routines.
http://www.ccsinfo.com/forum/viewtopic.php?t=27812&start=11
http://www.ccsinfo.com/forum/viewtopic.php?t=27812&start=11 |
