How to convert a binary #
agompert
PostPosted: Mon Jan 21, 2008 10:14 pm     Reply with quote
I'm new to C programing.
I was wondering if someone could give me a little direction on how to convert a 16 bit binary # into a form I can output to the lcd_putc() function which is in the lcd.c include file? Or maybe which function should I use to do this conversion ?
PostPosted: Mon Jan 21, 2008 10:48 pm     Reply with quote
Do it with printf. In CCS, printf has a special feature where its output
can be re-directed to another function. You can re-direct it to the
lcd_putc() function and it will be displayed on the LCD. Printf will do
the conversion from an integer to ASCII for you.
See this example program:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
This program displays a floating point number on the LCD.
If you want to display an 'int16' variable on the LCD, then use "%lu"
instead of "%f" in the printf statement.
