Joined: 07 Jan 2004 Posts: 1616 Location: Central Illinois, USA
Problem with WinXP USB CDC w/CCS USB-Serial drivers
Posted: Wed Jan 23, 2008 2:58 pm
Ok, I had this working once upon a time...
Since I can't get my normal app to work, I backpedaled to ex_usb_serial2.c
and it has the same problem.
Windows Enumerates the device. I can connect via hyperterm no problem.
Printing more than a few lines of information cause the PIC to re-enumerate causing hyperterminal to no longer function...
I must:
Exit hyperterm
re-plug the PIC board (so it can re-enumerate again)
restart hyperterm
And watch it happen over again.
I'm doing this on a PIC18F2550 on an meLabs USB protoboard and both my code and the example worked with previous versions of PCH (I'm now using PCHWD).
-Ben
p.s. I tried this on Fedora Core 8 and have the same problems. (using minicom instead)
Posted: Wed Jan 23, 2008 3:03 pm
Use a file comparison utility on the source files for each version of PCH.
See if there's a difference in the new version that breaks your application.
bkamen
Posted: Wed Jan 23, 2008 3:10 pm
I was afraid someone would say that. :|
Yay - time to go look for the needle in the haystack.
I don't know how long ago this broke.. maybe last year sometime... how many versions have there been since then?
