		| Author | Message |
		| cypher
				| RS232 problem with Internal Oscillator |
				|  Posted: Thu Jan 17, 2008 5:44 pm |   |
				| Hi, I'm having some trouble with getting my printf command working.  I'm using a PIC18LF6722 (the low power version).  I'm using the internal osciallator at 4MHz.  I do not have a serial driver such as a MAX232.  The RX and TX go straight from the PIC to the serial port.  All I get on the output is some garbage.  Here's the code:
  	  | Code: |  	  | #include <18F6722.h>
 #device ADC=10
 #include <stdio.h>
 #include <math.h>
 #include <ctype.h>
 #include <stdlib.h>
 #fuses INTRC,NOWDT,NOLVP
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
 printf("Hello World");
 I know the MAX232 inverts the serial pins, but since I didn't have one, I used the invert parameter in the *use rs232 directive, but the complier complained with the following command:
 USE parameter value is out of range   H/W USART can not invert
 Any suggestions what I'm missing?
		| PCM programmer
		| cypher
				|  Posted: Thu Jan 17, 2008 6:32 pm |   |
				| Thanks!  That worked.  I don't have a 22K, but a 1K in series.  But it works. |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
