erik006
| dspic30f2010 pwm question |
Posted: Sat Jan 05, 2008 6:33 pm |
Has anyone gotten pwm support to work on this dsPIC? I can verify my chip is working, but pwm does not seem to work..
Erik |
Guest_7068 Guest
Posted: Sun Jan 06, 2008 2:29 am |
| The ex_pwm example code has working code for the 30F2010 chip. |
erik006
Posted: Sun Jan 06, 2008 8:28 am |
I suppose you have tested that code with the dsPIC? I had tried it previously and it did not work for me.. no pwm output on any of the pins, & even though everything seems to be setup correctly, the ICD shows that the timers & adc are not setup at all..
Any help?
Erik |
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
Posted: Sun Jan 06, 2008 3:00 pm |
I used this example on the 24FJ64GA004 micro, did not work at first however I reported this to CCS tech support with my findings and a fix was made, I can use the PWM (OC) Output Compare on my micro now with Version 4.064 _________________ What has been learnt if you make the same mistake?  |
