		| View previous topic :: View next topic   |
			ArMo
				| i2c between PIC's 16F74 |
				 Posted: Wed Dec 26, 2007 2:17 pm     |
I'm have some problem with my communicaton i2c between PIC16F74's...
I try to write one simple code for write/read between pic's, but my code don't read nothing.
Can someone show me where I have gone wrong? I'm a little confused.
//MASTER CODE:
#include <16F74.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#use delay(clock=16000000)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
//=============== GLOBAIS ======================
char s[]= {"- write -"};
char buffer[0x20];
char data;
int i,j;
void led()
   output_bit(PIN_A3,0);
   output_bit(PIN_A3,1);
void buffer()
   if(j<25)
   buffer[j]=data;
   j++;
   else j=0;
   port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   // TODO: USER CODE!!
//================= WRITE =====================
   if(!input(PIN_A0)) // write in slave
   i2c_start(); // Begin
   i2c_write(0xa0); // Control Byte (write)
   i2c_write(0x20); // Address
   for (i=0;i<10;i++)
      i2c_write(s[i]); // Data (10 char's)
   i2c_stop(); // end
   led(); // Led
//============= READ ===================
   if(!input(PIN_A2)) // read in slave
   i2c_start(); // begin
   i2c_write(0xA0);
   i2c_write(0x20);
   i2c_start();
   i2c_write(0xA1);
   for(j=0;j<25;j++)
      data = i2c_read();
      buffer();
   i2c_stop();
   led();
// SLAVE CODE:
#include <16F74.h>
#device adc=8
#FUSES HS //Crystal osc (>4mhz)
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,address=0xA0)
//============= GLOBAIS ==================
BYTE buffer[0x20];
char c;
int8 data;
char r[]="- Ok -";
int i=0;
int j;
//=========( BUFFER )========================
void buffer()
   if (i<25> state=0: Address match received with R/W bit clear
//=========( STATE<80 )======================
if(state<0x80>1)
   data=rx;
   c=data;
   putc(c);
   buffer();
//=====( STATE=80 )=======================
if(state==0x80) // Address match received with R/W bit set
   i2c_start();
   i2c_write(0x20);
   for (j=0;j<10;j++)
      i2c_write(r[j]);
   i2c_stop();
//=====( STATE<FF )==================
if(state<0xFF) //Transmission completed and acknowledged
void main ()
   enable_interrupts(INT_SSP);
   while (1)
Thank you for your time.
ArMo
				 Posted: Wed Dec 26, 2007 2:24 pm     |
				 	  | Quote: | 	 		  | if (i<25> state=0: |
The code in your post is messed up, because of a setting in the forum.
To fix it, do this:
Click on the word "Profile", in the upper left corner of the CCS forum
page.   Then edit your user profile and select the box to disable HTML.
Set it for "No":
 	  | Quote: | 	 		  | Always allow HTML:   No |
Then edit your post, delete the code, and paste in new code.
This will fix the problem.  Then the code will look OK. |
			ArMo
				 Posted: Wed Dec 26, 2007 2:39 pm     |
				| I do it... that's all rigth now ??? |
				 Posted: Wed Dec 26, 2007 2:44 pm     |
				 	  | Quote: | 	 		  if (i<25> state=0: Address match received with R/W bit clear
if(state<0x80>1)
It's still not fixed.
1.  You need to edit your original post.   Delete all the code.
2.  Copy and paste in new code, from your editor (MPLAB or CCS).
3.  Look below the posting window.   Make sure that this box is selected:
 	  | Quote: | 	 		  | x Disable HTML in this post |
4. Then press the Submit button. |
			ArMo
				 Posted: Thu Dec 27, 2007 6:04 am     |
				| I did it ... it´s ok ??  PLEASE HELP ME |
				 Posted: Thu Dec 27, 2007 1:26 pm     |
				The code is not posted OK.   Look at it.  Many statements are messed up.
I suggest that you give up on posting the code.   Instead, try the
following:
Use the CCS example file code, Ex_Slave.c, for the Slave PIC.
It's in this directory:
 	  | Quote: |
c:\Program Files\picc\Examples\Ex_Slave.c
Use the code in this post for the Master PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3 |
