		| Author | Message |
		| Ramey
				| problem with getenv("DEVICE) |
				|  Posted: Thu Dec 20, 2007 4:25 pm |   |
				| I'm using the August '07 version of PCH.  Compiling the  following test program
 [code]
 #define __USB_PIC_PERIF__ 1
 //#include <18F4450.h>
 #include <18F4550.h>
 #if getenv("DEVICE")=="PIC18F4450"
 #endif
 #if getenv("DEVICE")=="PIC18F4550"
 #endif
 [code]
 Fails with the following error.
 [code]
 Executing: "C:\Program Files\PICC18\Ccsc.exe" "test.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
 *** Error 27 "test.c" Line 9(21,23): Expression must evaluate to a constant
 *** Error 48 "test.c" Line 10(24,34): Expecting a (
 2 Errors,  0 Warnings.
 Halting build on first failure as requested.
 BUILD FAILED: Thu Dec 20 14:15:39 2007
 [/code]
 Any sort of small changes, different device, switching order etc. result in the same error on the second usage of getenv("DEVICE").
 Any help appreciated[/code]
		| PCM programmer
				|  Posted: Thu Dec 20, 2007 4:37 pm |   |
				| "August '07" is not a version number.   Post the real version number. Do a compilation that doesn't result in an error.   Then look in the
 project directory and find the .LST file.   The version number is given
 near the start of the file.   It's a number such as 3.249, 4.013, 4.064, etc.
 Post it.
		| Ramey
				| version # |
				|  Posted: Thu Dec 20, 2007 5:22 pm |   |
				| pch Version 4.055 |  |
		| PCM programmer
				|  Posted: Thu Dec 20, 2007 5:33 pm |   |
				| Put parentheses around each statement, as shown in bold below:
  	  | Quote: |  	  | #if (getenv("DEVICE")=="PIC18F4450") #endif
 #if (getenv("DEVICE")=="PIC18F4550")
 #endif
		| Ken Johnson
				|  Posted: Thu Dec 20, 2007 6:54 pm |   |
				| I reported this to ccs on Tuesday - they said it's fixed in the next release
 Ken
