jruibarroso
| HELP !! pic16f84A timer0 don't work |
Posted: Mon Dec 17, 2007 1:04 pm |
any one could see where is the error please
TIMER0 don't work , doesn't count and PULSE_LED don't pulse
#include <16F84A.h>
#FUSES HS //High speed Osc (> 4mhz)
#use delay(clock=8388608)
#define INTS_PER_SECOND 16 // (8.388.608/4*256*256)) one second each overflow
#define PULSE_LED PIN_B4
#define RELE1 PIN_A1
#define RELE2 PIN_A0
#define RELE3 PIN_B6
#define ON PIN_A2
int int_count;
int sec,min,hrs;
#int_RTCC
void RTCC_isr()
output_low(PULSE_LED);
if(--int_count==0)
output_high(PULSE_LED);
++sec;
if (sec>59){++min;sec=0;}
if (min>59){++hrs;min=0;}
if (hrs>23){hrs=0;}
int_count=INTS_PER_SECOND;
enable_interrupts(INT_RTCC);
while(true){
my code ~~~~~~~~
THANK YOU ALL |
Posted: Mon Dec 17, 2007 1:55 pm |
| Quote: | #define INTS_PER_SECOND 16 // (8.388.608/4*256*256))
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1); |
Your #define statement says you are using "div by 256", but your
setup_timer_0() statement uses "div by 1". That's a mistake.
Also, you need to initialize the 'int_count' variable in main(), before
you enable interrupts. Initialize it to "INTS_PER_SECOND". |
PICdawg
Posted: Mon Dec 17, 2007 1:56 pm |
Keep in mind the following...
Timer0 is an 8 bit timer/counter. Your code says use the internal clock with no prescaler. That means the RTCC is incrementing every 0.4768us. (this time comes from 1/(8388608/4)) That means your rollover occurs every 122us, not every 1/16th of a sec like your code expects. (rollover occurs every 0.4768us * 256 counts per rollover = 122us)
Therefore, with your prescaler set to one, you need to preset a counter to 8192 and begin decrementing from there. (8192 rollovers * 122us per rollover = 1sec)
Make sense? |
PICdawg
Posted: Mon Dec 17, 2007 2:06 pm |
| If you go ahead and use the prescaler set to 256, then your counter needs to be initialized to 32. (8192/256=32). As PCM programmer indicated, you are missing this initialization line... |
