| How to connect RS232 (DB9) connector to PIC16F690? |
Posted: Tue Oct 16, 2007 9:38 am |
| I have a PicKit2. Thanks! |
Posted: Tue Oct 16, 2007 12:08 pm |
The PicKit with a 16F690 is really a very minimal board. It doesn't have
a MAX232 level shifter on it. It doesn't have any easy way to connect
to a PC serial port.
The schematic of the "Low Pin Count" board shows that it has very few
features. It has a few LEDs. The Port B pins are not available on the
header.
http://ww1.microchip.com/downloads/en/DeviceDoc/Low%20Pin%20Count%20User%20Guide%2051556a.pdf
You could create a software UART, and use the INVERT option. Then
connect the Rx pin of your soft UART (on the PIC) to pin 3 on the
PC's DB9 connector with a series resistor, as shown in this schematic:
http://www.instructables.com/files/orig/FVI/TR35/VW1EP27VUPP/FVITR35VW1EP27VUPP.gif
The Tx pin on the PIC (from a software UART) would go to pin 2 on the
DB9 connector. This is not shown on the schematic.
You must also have a ground connection between the PicKit board
and pin 5 on the DB-9 connector.
Pins C4 and C5 are free for use on that board. So connect pin 3 on
the DB9 through a 22K resistor to pin C5. Then connect pin 2 on the
DB9 with a wire to pin C4. Also connect pin 5 on the DB9 to GND,
which is pin 14 on the header. Make sure you understand the pin
number layout on the header connector and the DB9, and connect
everything to the right pins, or you might destroy the board.
Here's a test program.
#include <16F690.h>
#fuses INTRC_IO, NOWDT, NOBROWNOUT, PUT, NOMCLR
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5)
char c;
printf("Start \n\r");
c = getc();
putc(c);
Posted: Tue Oct 16, 2007 1:12 pm |
| I'm getting a MAX232 dip from inventory right now. I'm assuming it's easier with the MAX232. How would that be connected thanks! |
jecottrell
Posted: Tue Oct 16, 2007 1:45 pm |
Google the datasheet.
Follow the example schematic on the datasheet. |
Posted: Tue Oct 16, 2007 1:47 pm |
Here's a schematic that shows how to connect a 16F690 to a MAX232
chip and to a DB9. The MAX232 and the DB9 will be attached to the
prototyping area on the board.
http://www.melabs.com/downloads/LABX20SC_06.pdf
You will need a "1 to 1" (also called "straight-through") serial cable
to connect between the DB9 for the board and the DB9 on the back
of your PC.
Note that the MAX232 requires 5 capacitors. Three of them are shown
below the MAX232 symbol in the schematic. If you have a MAX232A,
then you can use 0.1 uF capacitors instead of the 1.0 uF value.
The connections on the DB9 from pins 1 to 6 to 4, and from 7 to 8
really aren't needed. All you need are the connections going to
pins 2, 3, and 5.
With the MAX232, you should use the hardware UART on pins B7 and B5,
so the test program should now be this:
| Code: | #include <16F690.h>
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
char c;
c = getc();
putc(c);
Thomas82 Guest
Posted: Wed Oct 17, 2007 3:42 pm |
I have everything connected just like the schematic. I'm getting output in Hyperterminal, and I'm getting the LEDS to blink.
Unfortunately the output in hyperterminal looks like this:
ß ß ß ß ßß ß ß ß ß ß ß ß ß ß ß ß ß
ß ÷ ß ß ß ß ß ß ÷÷ ß ÷ß ß ß
ß ß ß ß ß ß ß ß ÷ ß ÷ ÷ ß ß
ß ß ß ß ß ß ß ß ß ß ß ß ß ß ß ß
ß ß ß ß ß ß ß ßß ß ß ß ß ß ß ß ß ß ÷ ß ÷
ß ß ß ß ÷ ß ß ß ß ß ÷ß ßß ß ß ß ß
÷ ß ß ß ß ß ß ßß ß ß ß ÷ ß ß÷ ß ß ß ÷ ß
ß÷ ß ß ÷ ß ß ßß ß ß ß ß ß ß
ß ßß ß ÷ ß ÷ ß ÷ß ÷ ß ß ß ß ß ß ÷ ß ß
ß ÷ ß ß ß ß ß ß ß ß÷ ß
ß ß ß ß ß ÷ ß ß ß ß ßß
ß ÷ ß ß ß ÷ ß ß ß ß ß ß ÷ ÷ ß ß
ß ß ÷ ß ÷ ß ß ÷ ÷ ß ß ß ß ß ß ß ß
ß ß ß ß ÷ ß ß ß ß ß
ß ß ÷ ß ß ÷ ß ß ß ß ß ß ß ÷ ß ß
ß ß ß ß ß ß ÷ß ÷ ß ß ÷ ß ß ß ß
ß ß ß ß ß ß ß ßß ÷ ß ßß ß ÷ ß ß
ß ß ÷ ß ß ÷ ÷ ß ÷ ß ÷ß ßß ß ß ß ß ß ß ß ß
ß ß ß ßß ß ß ß ß ß ß ß ß ÷ ß ß ß ßß
ß ß ÷ ß ß ÷ ß ß ÷ ß ÷ ß ß ÷ ß ÷ ß
ß ß ß ß ÷ ßß ß ß ÷ ß ß ß ß ß ÷
BTW THANKS for all the help so far! |
Posted: Wed Oct 17, 2007 4:21 pm |
I tested it just now with compiler vs. 4.058 and it works OK.
I have a 3M breadboard with a 16F690 and a MAX232A on it,
and I programmed the PIC with an ICD2 from MPLAB.
It displays:
Etc., as I type in keys in a terminal window.
I suspect either your hardware is wrong, or maybe it's a problem
with your compiler. What's your compiler version ? It's listed at
the start of the .LST file, which will be in your project directory.
It's a 4-digit number such as 3.249, 4.013, 4.059, etc. |
ThomasC
Posted: Thu Oct 18, 2007 10:04 am |
It is version 4.059.
I just noticed two things. The caps in the diagram are polarized; the ones I installed are not polarized.
I did a search and found this neat gif that you posted earlier.
http://www.geocities.com/SiliconValley/Network/3656/c2c/rs232x.gif
Does this schematic apply to the to PIC16F690? I've also checked in the back of the manual like you said and it shows Vcc and hooked up to + and Gnd hooked to ground. I hooked them up appropriately and am trying it as we speak.
I'm also reading your old posts in this thread as we speak:
http://www.ccsinfo.com/forum/viewtopic.php?t=26898
Thanks this getting the ball rolling again while I'm at work.  |
Posted: Thu Oct 18, 2007 10:08 am |
That schematic can be used with the 16F690. The striped side of the
caps is the negative side. |
Posted: Fri Oct 19, 2007 9:30 am |
| Is it mandatory that the caps are polarized? All I have are non polarized caps? |
SherpaDoug
Posted: Fri Oct 19, 2007 10:16 am |
Non polarized caps are fine. Just don't use polarized caps the wrong way around. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Mon Oct 22, 2007 8:02 am |
Success! The hardware connections are correct. It was buggy code.
I put the printf commands after a "for" loop. It worked after I put the prinf commands before the "for" loop.
Now it will output "Start" and "asdf;lkajsdf" or whatever I type in. Thanks everyone. |
Posted: Mon Oct 29, 2007 12:14 am |
Hi
Im new to all this and am trying to connect a pic16f690 to a max232. I can do the hardware side of things but writing the code is the bit i need help with. I am using a pickit2 with mplab7.6. Do i just copy the code given earlier and off it goes. If not can sombody give me the enitre code and instructions on how to enter it into mplab.
Thanks in advance |
Posted: Tue Oct 30, 2007 3:13 pm |
| Thanks for that. Tried entering the code into mplab and compiling it and comes up with a build error saying pcm compiler isnt installed. Where do i find this compiler or should i change the compiler. How do i do this? Thanks very much |
