		| View previous topic :: View next topic   |
			Evan Guest
				| RS232 problem (not receive the data from the computer) |
				 Posted: Mon Nov 12, 2007 1:08 am     |
				hell All:
I have an 18f4550 and MAX3232CPE chip that i am using to communicate with a computer (hyperterminal).
  RS232_PIN_2 ----PIN7_MAX3232_PIN10---------PIN_A3_18f4550
  RS232_PIN_3 ----PIN8_MAX3232_PIN9---------PIN_A2_18f4550
sending data to the computer using printf==>OK
But not receive the data from the computer
#include <18F4550.h>
#fuses hs,NOWDT,PROTECT,NOLVP,NODEBUG,MCLR,NOVREGEN
#use delay (clock=8000000)
#use rs232(baud=9600,parity=N, xmit=PIN_A3,rcv=PIN_A2,bits=8)
void main(void){
char c;
printf("\r\n\RS-232 int is ok \r\n\n");   // have display ,is ok
while(TRUE){
   c = getc(); //have problem!!!
   putc(c);    //no display is NG
  printf("\r\nSize: %u Bytes\r\n",c); //no display is NG
			Evan Guest
				| Re: RS232 problem (not receive the data from the computer) |
				 Posted: Mon Nov 12, 2007 1:11 am     |
				 	  | Evan wrote: | 	 		  hell All:
Version 4.057
void main(void){
char c;
while(TRUE){
				 Posted: Mon Nov 12, 2007 4:31 am     |
				In the PIC processor the I/O pins are multiplexed for use by several hardware functions. On program startup you have to configure the I/O pins for the hardware function that you want to use. Check the datasheet of the PIC18F4550, Table 10-1 for pin A2: 	  | Quote: | 	 		  | PORTA<2> data input. Disabled when analog functions enabled; |
By default PIN_A2 is configured as an analog input, if you want to use it as a digital input you have to disable the analog port: 	  | Code: | 	 		  | setup_adc_ports(NO_ANALOGS); |
Just wondering: Why are you not using the hardware UART on pins C6 and C7? |
			Evan Guest
				| Now is the same question |
				 Posted: Mon Nov 12, 2007 6:32 pm     |
				Hi ckielstra
Now is the same question =>not receive the data from the computer.
Im using the hardware SPI on pins C7,B0,B1 Connection SD CARD .
Thanks for your reply.
 Evan |
