problem in proximity sensor signal detection...
karthickiw
PostPosted: Wed Nov 21, 2007 8:51 pm     Reply with quote
hai,
i count the proximity sensor data.. i connect the seven segment
(A point) and proximity output in same pin RB7. i write the external interrupt to read the proximity data that time i configure the port as input port.. and then configure the port as output port and display the count data in seven segment. but program is count three times only.... my program is show below...
i used RB0 for other interrupt...
#include<16f873a.h>
#include<math.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#byte port_b=6
int CONST LED_MAP[10] = {0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xe6};
#define LOWTOHIGH TRUE
#define HIGHTOLOW FALSE
long int count=0;
long int d1,d2,d3,d4;
short int dbutton7;
int last1=0;
int current;
void display(long int a1)     // display function for segment LED
set_tris_b(0x01);   //set RB0- Input and other are output...
//delay_ms(20);
 d1=a1/1000;                  //separate four digits
 d2=(a1-1000*d1)/100;
 d3=(a1-1000*d1-100*d2)/10;
 d4=(a1-1000*d1-100*d2-10*d3);
output_high(pin_c4);
port_b= LED_MAP[d1];
delay_ms(1);
output_low(pin_c4);
output_high(pin_c5);
port_b= LED_MAP[d2];
delay_ms(1);
output_low(pin_c5);
output_high(pin_c6);
port_b= LED_MAP[d3];
delay_ms(1);
output_low(pin_c6);
output_high(pin_c7);
port_b= LED_MAP[d4];
delay_ms(1);
output_low(pin_c7);
last1=current;
set_tris_b(0x81); // set RB7 and RB0 are input and other are output..
#int_rb
void detect_rb_change() {
   static int last=0;
   set_tris_b(0x81);
   current=input_b();
   if ((!bit_test(last,7))&&(bit_test(current,7))) {dbutton7=1;}
   last=current;
void main() {
   dbutton7=0;
   enable_interrupts(INT_RB);
   output_low(PIN_a0);
   while (TRUE) {
        display(count);
        if(dbutton7)
        count=count+1;
        dbutton7=FALSE;
        if ( count>=9999) count=0;
