poyns
| html form parameter processing |
Posted: Sat Mar 03, 2007 3:24 am |
Hi
I’m trying to implement a simple logon page (username and password fields) then forward to a settings page, using the embedded internet development board.
My understanding of HTTP_Task() (through StackTask()) is that all the parameters of a HTML form are passed through the callback function http_exec_cgi() before the function http_get_page() serves the requested web page. But even the simple web server (ex15.c) supplied with the kit serves the page before parsing the form fields. (I changed the printf's in the example slightly to make the problem more presentable)
My question: is there any way to ensure all parameters are processed before returning or forwarding to another page ie ensure http_get_page() occurs after http_exec_cgi() is done.
I expected the output from ex15.c to be:
[typed the boards ip into ie6, requesting INDEX_PAGE]
http_get_page(): request for '/' (FILE=856)
[fields passing through cgi fn]
http_exec_cgi(): FILE=856 KEY='lcd' VAL='hello there!'
http_exec_cgi(): FILE=856 KEY='led1' VAL='1'
http_exec_cgi(): FILE=856 KEY='led2' VAL='1'
[returning to the orignal page from the submit button]
Actual output from ex15.c is
[returning to the page from the submit before params parse!]
I would greatly appreciate any advice and thanks in advance.
Regards,
Seamus
// ex15.c - Example 15 from the Embedded Internet/Embedded Ethernet tutorial
// A webserver that accepts GET and POST commands.
// NOTE: Change the code in IPAddrInit() to your desired IP address, which
// is based on your network.
#define STACK_USE_ICMP 1
#define STACK_USE_ARP 1
#define STACK_USE_TCP 1
#define STACK_USE_HTTP 1
#include "ccstcpip.h"
#if STACK_USE_CCS_PICENS
#include "drivers\mlcd.c"
#else
#include "drivers\dlcd.c"
//here is this examples / page
const char HTML_INDEX_PAGE[]="
<HTML><BODY BGCOLOR=#FFFFFF TEXT=#000000>
<IMG SRC=\"http://www.ccsinfo.com/pix/CCSlogotiny.gif\"><P>
<H1>CCS HTTP/CGI EXAMPLE</H1>
<FORM METHOD=GET>
<P>LCD: <INPUT TYPE=\"text\" NAME=\"lcd\" size=20 maxlength=16>
<BR>LED1:<INPUT type=\"radio\" name=\"led1\" value=1>ON
<INPUT type=\"radio\" name=\"led1\" value=0 checked>OFF
<BR>LED2:<INPUT type=\"radio\" name=\"led2\" value=1>ON
<INPUT type=\"radio\" name=\"led2\" value=0 checked>OFF
<BR><INPUT TYPE=\"submit\"></FORM>
<P><A HREF=\"/analog\">Analog Readings</A>
</BODY></HTML>
const char HTML_ANALOG_PAGE[]="
<H1>PICNET ADC READINGS</H1>
<P>%0
<BR>%1
<P><A HREF=\"/\">Change LCD/LEDs</A>
</BODY></HTML>
//this is a callback function to the HTTP stack. see http.c
//this demo provides to web "pages", an index (/) and an about page (/about)
int32 http_get_page(char *file_str) {
int32 file_loc=0;
static char index[]="/";
static char about[]="/analog";
printf("\nhttp_get_page(): request for '%s' ",file_str);
if (stricmp(file_str,index)==0)
file_loc=label_address(HTML_INDEX_PAGE);
else if (stricmp(file_str,about)==0)
file_loc=label_address(HTML_ANALOG_PAGE);
if (file_loc)
printf("(FILE=%LU)\n",file_loc);
printf("(File Not Found)\n");
return(file_loc);
// this demo provides handling for two formatting chars, %0 and %1.
// %0 is ADC for channel 0, %1 is ADC for channel 1.
int8 http_format_char(int32 file, char id, char *str, int8 max_ret) {
char new_str[20];
int8 len=0;
int8 i;
*str=0;
switch(id) {
case '0':
set_adc_channel(0);
delay_us(100);
i=read_adc();
sprintf(new_str,"<B>AN0 = </B>0x%X",i);
len=strlen(new_str);
case '1':
#if STACK_USE_CCS_PICNET
set_adc_channel(1);
delay_us(100);
i=read_adc();
sprintf(new_str,"<B>AN1 = </B>0x%X",i);
#else
len=0;
if (len) {
if (len>max_ret) {len=max_ret;}
memcpy(str,new_str,len);
return(len);
//in this example it verifies that "pwd" is "master", if it is
//then it sets led1 and led2 ("led1" and "led2") based on their value
//and changes the lcd screen ("lcd").
void http_exec_cgi(int32 file, char *key, char *val) {
static char led1_key[]="led1";
static char led2_key[]="led2";
static char lcd_key[]="lcd";
int8 v;
printf("\nhttp_exec_cgi(): FILE=%LD KEY='%S' VAL='%S'", file, key, val);
if (stricmp(key,led1_key)==0) {
v=atoi(val);
if (v) {output_low(USER_LED1);}
else {output_high(USER_LED1);}
if (stricmp(key,led2_key)==0) {
v=atoi(val);
if (v) {output_low(USER_LED2);}
else {output_high(USER_LED2);}
if (stricmp(key,lcd_key)==0) {
printf(lcd_putc,"\f%s",val);
void main(void) {
MACAddrInit();
IPAddrDefault();
init_user_io();
lcd_init();
printf(lcd_putc,"\fCCS CGI Example\nWaiting");
printf("\r\n\nCCS CGI Example\r\nWaiting");
set_adc_channel(0);
StackInit();
while(TRUE) {
StackTask();
