		| Author | Message |
		| Hans Wedemeyer
				| Question about #build (reset=0X200, interrupt=0X208) |
				|  Posted: Fri Sep 21, 2007 1:05 pm |   |
				| I'm trying to move the application reset vector and interrupt vectors out of the boot block.
 #build(reset=0x200,interrupt=0X208)
 #org 0X0, 0X1FF {} // don't use boot block
 This compiles, but the interrupts are not working !
 I just called CCS help and was told to use jump_to_isr() !
 The latest help file has very little information on how to use this here is all it says: (with my comments:
 int_global       // what is this and where does it go ?
 void global_isr(void)   // does this replace the CCS generated isr handling ?
 jump_to_isr(isr_address);   // do I need to add a statement for every ISR ?
 Lastly how do I get the address of the ISR ? is this done dynamically or at compile time ?
		| PCM programmer
				|  Posted: Fri Sep 21, 2007 1:24 pm |   |
				| There's an example of its use in Ex_Bootloader.c. It's in this location:
  	  | Quote: |  	  | c:\Program Files\PICC\Examples |
		| Hans Wedemeyer
				|  Posted: Fri Sep 21, 2007 1:57 pm |   |
				| The example is not clear about what happens to the original isr dispatcher.
 Does this new isr() replace the isr dispatcher ?
 The value LOADER_END+5 seems to be specific to the ex_loader example.
 But what address do I need to use ?
 Is it  00208:  GOTO   02CE  // the isr dispatcher  (from lst file)
 This is not clear at all.
 #int_global
 void isr(void)
 jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
 I'm lost ...
		| Ttelmah Guest
				|  Posted: Fri Sep 21, 2007 2:47 pm |   |
				| The compiler generates the normal dispatcher at the 0x208 address (this is what the 'build' statement tells it to do). You need to jump the physical interrupt, to this address, with the routine placed in the bootloader code.
		| Hans Wedemeyer
				|  Posted: Fri Sep 21, 2007 4:16 pm |   |
				|  	  | Ttelmah wrote: |  	  | The compiler generates the normal dispatcher at th 0x208 address (this is what the 'build' statement tells it to do). You need to jump the physical interrupt, to this address, with the routine placed in the bootloader code.
 Not sure I understand that.
 The bootloader is a separate program from the actual application.  Not sure I see the connection.
 Lets say there is NO bootloader involved, and all I wanted was to operate the program with build (reset=0200, interrupt=0208) and code left out of the boot block.
 Where does the jump_to_isr(address) go in the application code ?
 Best regards
 Hans W
		| Ttelmah Guest
				|  Posted: Sat Sep 22, 2007 2:09 am |   |
				| It doesn't. To use interrupts, the bootloader, _must_ vector the interrupt jump, 'into' the real code. The following assumes only low priority interrupts are being used - otherwise two vectors come into play.
 If you generate a program, with the build statement given, the compiler generates:
 0x200     GOTO main_program_entry
 0x208     The ISR handler
 The hardware still generates a call to address 8 (this cannot be changed), so the bootloader needs to itself contain an 'int_global' handler, which just comprises a jump to address 0x208.
 The bootloader code, must provide this relocation.
		| Hans Wedemeyer
				|  Posted: Sat Sep 22, 2007 8:20 am |   |
				|  	  | Ttelmah wrote: |  	  | It doesn't. To use interrupts, the bootloader, _must_ vector the interrupt jump, 'into' the real code. The following assumes only low priority interrupts are being used - otherwise two vectors come into play.
 Thanks for the explanation.
 I now see the reason why top end boot loaders are more popular, almost no code changes to the loaded program but at the price of exposing one's code.
 About the high priority interrupts:  In the PIC18F6720 the High Priority interrupt vectors starts at 0x0008 and the Low at 0X0018 .
 So if I understand this the should be another jump_to_isr( 0x0218) to cater  for the Low priority interrupts.
 Am I correct in that assumption ?
		| Ttelmah Guest
				|  Posted: Sat Sep 22, 2007 8:31 am |   |
				| Only if you are using both. If interrupt priority is disabled, the 08 address is used.
		| Hans Wedemeyer
				|  Posted: Sat Sep 22, 2007 8:47 am |   |
				|  	  | Ttelmah wrote: |  	  | Only if you are using both. If interrupt priority is disabled, the 08 address is used.
 Yes I just noticed that.
 I added  #device HIGH_INTS=TRUE and tthe compiler generated this.  To me it seems the one statement handles both.
 Looks like the code handles the High Priority Interupts  at 00008:  GOTO   2008 and RETFIE's back into a few NOPs and then hits the low priority Interrupts  and finally RETFIE's out at 0001C:  RETFIE 0
 I wonder if all those nop's are needed !
 Thanks for the help I think I've got the hang of it now.
 Best regards
 Hans W
 .................... void isr(void)
 ....................    jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
 00008:  GOTO   2008
 0000C:  NOP
 0000E:  NOP
 00010:  NOP
 00012:  NOP
 00014:  NOP
 00016:  NOP
 00018:  GOTO   2018
 0001C:  RETFIE 0
		| Guest
				|  Posted: Sat Sep 22, 2007 9:45 am |   |
				| Yes. The 'jump_to_isr' instruction will automatically handle both. This is the difference between using this, and a manual 'goto'.
 What else are you going to put in the space between the jumps?. There is not enough space for any useable code, and nop is safe.
 It doesn't "retfie back to the NOP's". When 'retfie' is executed at the end f the handler in the main code, the handler returns to where the interrupt occured. The address is on the stack.
 The NOP's should never be executed.
		| Hans Wedemeyer
				|  Posted: Sat Sep 22, 2007 4:48 pm |   |
				|  	  | Anonymous wrote: |  	  | Yes. The 'jump_to_isr' instruction will automatically handle both. This is the difference between using this, and a manual 'goto'.
 Thanks for the help.  This bootloader is also working fine and code is protected from reads.
