PIC programming structure
gg
PostPosted: Fri Sep 07, 2007 8:38 pm     Reply with quote
What are some different code structure that I can use?
Re: PIC programming structure
PostPosted: Fri Sep 07, 2007 8:42 pm     Reply with quote
How I do implement FSM with pic?
PostPosted: Tue Sep 11, 2007 12:38 am     Reply with quote
See
h t t p : // ai-depot.com/FiniteStateMachines/FSM-Framework.html
(remove the spaces, as guest I cannot post urls)
One possibility might be the state increments under interrupt, another might be the state just alters in normal program execution.
Basic answer however:
Define yourself some states, and depending on some event or result alter it. Then in a switch/case or if/else statement start/call another routine to handle that state.
