tatokash
| PIC18F2550 USB and clock configuration |
Posted: Tue Aug 28, 2007 12:22 pm |
One more time... with feeling.
Why does this not work with a 12MHz crystal:
| Code: | #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL3,CPUDIV1,VREGEN,NOBROWNOUT,MCLR
But this works with a 20MHz crystal:
| Code: | #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOBROWNOUT,MCLR
Been banging my head against a wall. The 12MHz crystal would not work with any combination of CPUDIVx or PLLx. I foraged and found a 20MHz crystal and it works fine (of course with the config reg change). Can anyone tell me why? _________________ Don't ever stop learning... |
Douglas Kennedy
Posted: Tue Aug 28, 2007 1:56 pm |
Here is what I know
At 20Mhz
The 20 mhz external crystal is pre scalled by div 5 (PLL5) to 4mhz
PLL multiplies by 16 to 96Mhz USBDIV post scales with div by 2 to 48MHZ
CPU clock is post scaled with
CPUDIV1 by with div by 2 for 48 MHZ
#use delay(clock=48000000)
At 12Mhz
The 12 mhz external crystal is pre scalled by div 3 (PLL3) to 4mhz
The exact same result so both should work. I have had issues with certain chips running the CPU stage at 48Mhz...I know 32Mhz ( CPUDIV2) works every time. Try 32Mhz and see if that works |
Posted: Tue Aug 28, 2007 5:52 pm |
I tested this on a PicDem2-Plus with a 12 MHz crystal, with PCH vs. 4.053
and it puts out a 1 KHz squarewave on Pin B0.
| Code: | #include <18F4550.h>
#fuses HSPLL, PLL3, CPUDIV1, NOWDT, PUT, BROWNOUT, NOLVP
output_high(PIN_B0);
delay_us(500);
output_low(PIN_B0);
delay_us(500);
