reemy
| ds1307 help please |
Posted: Sat Aug 25, 2007 3:33 pm |
hi all
i have disturbing problem with rtc clock uses ds1037 ,its work just for one time then make load and stop working .please help me
here is my code:
#include <18f4620.h>
#include <stdlib.h>
#FUSES NOWDT, XT
#include<ds1307.c>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <INPUT.C>
int8 data, fb,value ,cmd;
long int eeprom_address,i,j;
int8 dow, hr, min, hr_eeprom, min_eeprom,sec,min_ring;
int Add1, Add2,duration;
int k, counter,address,prev_min;
int1 flag_ring,on_flag,int_flag;
#int_rda
void serial_isr() {
cmd=gethex();
if (cmd==0xc1)
i=0;
if (cmd==0xc2)
i=100;
}else
if (cmd==0xc3)
i=200;
if (cmd==0xc4)
i=300;
if (cmd==0xc5)
i=400;
if (cmd==0xc6)
i=500;
if (cmd==0xc7)
i=600;
if (cmd==0x77)//on
on_flag=1;
goto end;
if (cmd==0x88)//off
on_flag=0;
goto end;
if (cmd==0x99)//set clock
dow=gethex();
hr=gethex();
min=gethex();
write_ds1307(3,dow);
write_ds1307(2,hr);
write_ds1307(1,min);
goto end;
j=i;
address=i;
while(i<(j+72)) {
value =gethex();
if(((i%2)==0))
address++;
write_eeprom(address , value);
i++;}
end:
int_flag=1;
enable_interrupts(INT_RDA);
init_ds1307(); // initial DS1307
write_ds1307(0,0x59); //sec
write_ds1307(1,0x00); //min
write_ds1307(2,0x01); //hr
write_ds1307(3,0x01); //day
write_ds1307(4,0x01); //date
write_ds1307(5,0x01); //mnth
write_ds1307(6,0x01); //year
output_low(PIN_D0);
i=0;
while (TRUE) /
on_flag=1;
if (on_flag==1)
START:
dow = read_ds1307(3); //Determine the daya of the week
Add1=(dow-1)*100+1; //Start address equation due to dow
Add2=dow*100;
hr_eeprom = read_eeprom(Add1);
hr = read_ds1307(2); //Read the current hour
min = read_ds1307(1); //Read the current minute
if(min!=prev_min)
ring_flag=0;
for (counter=Add1;counter<Add2;counter+=2)
j = counter + 1;
hr_eeprom= read_eeprom(counter);
min_eeprom = read_eeprom(j);
if (hr_eeprom==hr)
if (min_eeprom == min)
output_high(PIN_D0);
output_low(PIN_D0);
min_ring = min_eeprom;
prev_min=min;
goto START;
} //end for
goto START;
} //end else
} //on_flag
}//while true
} //end main
i use driver on
http://www.sixca.com/micro/pic/ds1307/
problem is in code not in connection i guess
mickent
Posted: Sun Aug 26, 2007 8:38 am |
Try removing the single "/" after "while(TRUE)" _________________ Mick |
Posted: Sun Aug 26, 2007 11:00 am |
Change 'address' to a long int.
You are using variable j both in the interrupt and in main, don't do this as it will result in data corruption.
A few design hints:
- Use of the goto command is considered poor design. Basic andd assembly language use it everywhere but the C-language provides better language elements to get the same result.
- The large if/else construction is easier to understand and maintain when replace by a switch statement.
- Try to avoid using global variables. It is more difficult to check your code with global variables as we have to check your whole program to see if this variable is changed in some other places as well. You wouldn't have made the error of using variable 'j' both in the interrupt and in main when it had been a local variable. Another advantage is that the compiler can create more efficient code by reusing memory space of local variables. |
