EVAN Guest
| PIC16F690& LCDD.C |
Posted: Tue Aug 21, 2007 3:03 am |
hello,
Very its strange question I use CCS LIB LCDD.C , with PIC18F4550 connection, LCD is OK
LCD <-->PORTD is OK
code
#include<18F4550.h>
#fuses hs,NOWDT,PROTECT,NOLVP,NODEBUG
#use delay (clock=8000000)
#include <lcd.h>
void main(void){
lcd_init();
printf(lcd_putc,"\lcd Test is ok");//ok
while(1){;}
But PIC16F690 does not work Procedure when lcd_init(); endless loop
LCD <-->PORTC is NG no DISPLAY
#include <16f690.h>
#fuses INTRC,noWDT,MCLR,noPROTECT//,MCLR//,IOSC4
#use delay(clock=8000000)
#include <lcd.h>
void main(void){
lcd_init();
printf(lcd_putc,"\lcd Test is ok");// is no display
while(1){;}
Help me.Help me !
The CCS version is 3.249.
LIB LCDD.C
change ==>
#if defined(__PCH__)
#if defined use_portb_lcd
#byte lcd = 0xF81 // This puts the entire structure
#else
//#byte lcd = 0xF83 // is ok
#byte lcd =0xF87 //test is NG
#else
#byte lcd = 6 // on to port B (at address 6)
#else
//#byte lcd = 8 // on to port D (at address 8) --->isOK
#byte lcd = 7 // on to port C (at address 7) --->is NG
#define set_tris_lcd(x) set_tris_b(x)
#else
//#define set_tris_lcd(x) set_tris_d(x)
#define set_tris_lcd(x) set_tris_C(x)
EVAN Guest
| #include <lcd.c> |
Posted: Tue Aug 21, 2007 3:09 am |
| #include <lcd.c> |
EVAN Guest
| LCD DISPLAY OK |
Posted: Tue Aug 21, 2007 6:14 pm |
/*Now has been good, LCD display is ok
Thanks a lot!!! |
