Flex_lcd question...
PostPosted: Mon Mar 31, 2008 12:16 pm     Reply with quote
I'm using the flex_lcd4x20.c driver in a project. Periodically, I need to clear the LCD of all characters. Is calling the lcd_init function the best way to do this, or is there another, better way?
Dave
PostPosted: Mon Mar 31, 2008 12:44 pm     Reply with quote
The function interface is the same as for the CCS LCD drivers.
The following is from the start of the CCS LCD420.c driver file.
It lists the available commands:
//  lcd_putc(c)  Will display c on the next position of the LCD.
//           The following have special meaning:
//            \f  Clear display
//            \n  Go to start of second line
//            \b  Move back one position
Use this to clear the screen:
lcd_putc('\f');
meereck
PostPosted: Mon Mar 31, 2008 3:02 pm     Reply with quote
is there any simple way how to clear one row only? Or do I have to write a subroutine for that?
cheers Meereck
PostPosted: Mon Mar 31, 2008 3:12 pm     Reply with quote
Use lcd_gotoxy() to set the cursor to the start of the desired row,
and then use a printf() statement to fill the row with spaces.
meereck
PostPosted: Mon Mar 31, 2008 3:15 pm     Reply with quote
Right, that is the subroutine I was thinking of. Pity, there is no "\smthng" command for it.
Thank you for an instant reply.
