CCS - MPLAB BOOTLOADER Problem
Jacques95
PostPosted: Thu Aug 16, 2007 4:28 am     Reply with quote
I used 18F4550 demo board FS USB as HID USB. I would like to update the firmaware using USB with bootloader. So, I use Microchip standard BOOTLOADER using RB4. It worked with Microchip user'prog example.
So, now I want to download mine and then I got problem. I compile it using CCS PCH 3.235 and here under is the code I would like to download throught PDFSUSB.EXE.
#define _bootload
#ifdef _bootload
#define LOADER_END 0x7FF
#define LOADER_SIZE 0x6FF
#build(reset=LOADER_END+1, interrupt=LOADER_END+9)
#org 0, LOADER_END {}
void main(void) {
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(ccp_off);
setup_vref(VREF_LOW|-2);
setup_oscillator(FALSE);
output_toggle(PIN_A5);
Connection with PDFSUSB worked :
I got " PIC DEM FS USB 0 (BOOT)"
Then I tried to program and I got message
USB Read Failed.
Failed with error 6 : Descripteur non valide
Somebody has an idea about that error and why I could program it?
Here under is the setup file of the chip
#include <18F4550.h>
//#device ICD=TRUE removed to test the BOOTLOADER
#device adc=8
#FUSES WDT
#FUSES WDT4 //Watch Dog Timer uses 1:4 Postscale
#FUSES HSPLL //High Speed Crystal/Resonator with PLL enabled
#FUSES BORV20 //Brownout reset at 2.0V
//#FUSES DEBUG //Debug mode for ICD
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOPBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES CPB //Boot Block code protection
#FUSES PLL5 //No PLL PreScaler
#FUSES VREGEN
#FUSES USBDIV
#use delay(clock=48000000)
RockV
Same error
PostPosted: Mon Mar 31, 2008 12:03 pm     Reply with quote
I have same problem.
Seems to work but don't.
Checking the HEX file I have noticed that there is some code below 800h, I think this could be the problem.
But cant find how to push all the code over the 800h.
Maybe #ORG is not working properly.
RockV
flemse
PostPosted: Mon Mar 31, 2008 2:31 pm     Reply with quote
Look here.
http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
http://www.ccsinfo.com/forum/viewtopic.php?t=34065&highlight=tiny+bootloader
//F
meereck
PostPosted: Mon Mar 31, 2008 3:07 pm     Reply with quote
i worked with Microchip USB bootloader a year ago, and it was pretty successful.
The bootloader itself resides the memory space 0x000-0x7FF (called boot block)
this is how you can force the CCS compiler to put nothing within this space:
// START OF bootloader definition
#org 0, LOADER_END {} // nothing will replace the bootloader memory space
// END OF bootloader definition
As for your descriptor error, you surely rewrote something in the bootloader space. Flash the PIC with the bootloader HEX file.
!! As far as I remember, there was a bug somewhere. When the application asks you whether you want to overwrite fuses (Window called "Configuration Data"), I always had to click on Cancel.
In other words, you are not allowed to change Configuration bits (fuses). I havent found out why that occurs.
good luck
