Eeprom_programmer
| RS232 communication |
Posted: Mon Aug 13, 2007 7:37 am |
Hey,
Currently i am using a program on VB to turn on/0ff pins on a microcontroller.
Does anyone have an idee how to write this code in CCS?
Main:
' Use the programming port to receive
' data at 2400 baud
' Wait for the synch byte (255) and then
' get the PinNumber and PinState
Serin 16,16780,[WAIT(255),PinNumber,PinState]
' If PinState=0 Then go to GoLow
' otherwise go to GoHigh
Branch PinState,[GoLow,GoHigh]
Goto Main
' Set The pin low
GoLow:
LOW PinNumber
Goto Main
' Set the pin high
GoHigh:
HIGH PinNumber
Goto Main
Posted: Mon Aug 13, 2007 8:09 am |
| Code: | #include <18F458.h>
#fuses HS, NOWDT, PUT, NOLVP
#use delay(clock=16000000)
#use rs232 (baud=2400, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
void wait_pin_command()
int8 PinNumber;
int8 PinState;
while (getc() != 255)
; // wait for the synch byte
PinNumber = getc();
PinState = getc();
if (PinState == 0)
output_low(PinNumber);
output_high(PinNumber);
while (TRUE)
wait_pin_command();
