| Pointer use in function arguments |
Posted: Sun Jul 29, 2007 3:15 pm |
Assume that I have the following type description :
| Code: | typedef struct _NETWORK_DATA {
int8 IP[4];
int8 MAC[6];
int8 GATEWAY[4];
int8 MASK[4];
} NETWORK_DATA; |
And that I use a pointer to this type as an argument for a function. How should I use the pointer to modify the content of the received data ? In the following example, only the first assignation works. Is it the normal C behavior ? I thought that these two notations should be equivalent.
| Code: | void NovramGetNetworkData ( NETWORK_DATA * DATA ) {
DATA->MAC[0] = 101;
(*DATA).MAC[1] = 102;
Note.:
System : WinXP
PCWH V4.047
For info, here is the generated assembler :
| Code: | .................... DATA->MAC[0] = 101;
00398: MOVLW 04
0039A: ADDWF 34,W
0039C: MOVWF FE9
0039E: MOVLW 00
003A0: ADDWFC 35,W
003A2: MOVWF FEA
003A4: MOVLW 65
003A6: MOVWF FEF
.................... (*DATA).MAC[1] = 102;
003A8: MOVLW 05
003AA: MOVWF FE9
003AC: CLRF FEA
003AE: MOVLW 66
003B0: MOVWF FEF |
Dimitri |
Posted: Sun Jul 29, 2007 3:59 pm |
I installed PCH vs. 4.047, compiled the test program shown below,
and ran it in MPLAB simulator (vs. 7.41). It worked fine.
Here's the output of the program.
Here's the ASM code for the two lines. It looks the same.
0004: MOVLW 04
0006: ADDWF 18,W
0008: MOVWF FE9
000A: MOVLW 00
000C: ADDWFC 19,W
000E: MOVWF FEA
0010: MOVLW 65
0012: MOVWF FEF
0014: MOVLW 05
0016: ADDWF 18,W
0018: MOVWF FE9
001A: MOVLW 00
001C: ADDWFC 19,W
001E: MOVWF FEA
0020: MOVLW 66
0022: MOVWF FEF
Here's the test program. I used your code and just added
the necessary things to make a test program.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int8 IP[4];
int8 MAC[6];
int8 GATEWAY[4];
int8 MASK[4];
} NETWORK_DATA;
DATA->MAC[0] = 101;
NETWORK_DATA DATA;
NovramGetNetworkData(&DATA);
printf("%u, %u \n\r", DATA.MAC[0], DATA.MAC[1]);
Posted: Sun Jul 29, 2007 5:07 pm |
Thank you for the answer.
I made some more tests ( reducing my program until the code is correct ) and I found that the error comes from the fact that I used the magical option 'multiple compilation units' together with the 'link separately'
If I force all the sources into one file by including the '.c' files instead of the '.h' files and make a project without the multiple compilation units, the code is correctly generated.
I think I will report a bug on that point.
This is the test program to compile with the magical option :
Main file :
| Code: | #include "global.h"
int8 IP[4];
int8 MAC[6];
int8 GATEWAY[4];
int8 MASK[4];
} NETWORK_DATA;
(*DATA).MAC[0] = 105;
DATA->MAC[0] = 105;
void main(void) {
NETWORK_DATA NET_DATA;
NovramGetNetworkData ( &NET_DATA );
while(TRUE) {
Separate file (.h):
| Code: | #ifndef GLOBAL__H
#define GLOBAL__H
#include <18F4620.h>
#device *=16
#fuses H4, NOWDT, NOLVP, NODEBUG
#use delay(clock=40000000)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
void InitUserIO ( void );
#endif |
Separate file (.c):
void InitUserIO ( void ) {
*0xF92 = 0xDF; // PortA : A5 output, A4..A0 input
*0xF93 = *0xF93 & 0xCF; // PortB : B5..B4 output
*0xF94 = *0xF94 & 0xF8; // PortC : C2..C0 output
*0xF95 = *0xF95 & 0xFB; // PortD : D2 output
