kutkm_ti
input and output on the same pic pin ? |
Posted: Mon Jul 23, 2007 6:52 pm |
now i face a problem,
i no have any extra pin, so i need to drive a 7 segment led(commom anod) and at the same time, i need input for a push button,
tell me how to do...
any suggestion about when i push the button, it will not affect the led either on or off?
pin-->resistor-->led--> +5v
at the same pin, it will connect to a push button also.
rnielsen
Posted: Tue Jul 24, 2007 8:30 am |
I've wished I could use a pin as an output and input at the same time too but, due to physics, I really don't believe that it's possible to have a pin do both at the same time. It is possible to have a pin alternate between the two, being an input at one moment and then change to be an output another moment, but it's just not possible to be both at the same time.
You'll need to change your design or use a PIC with more I/O. I'm sure many of the folks here have run out of pins and had to re-do things. But, if you find out how to accomplish what you're looking for post it here. I'm sure we'd all like to know how to do it. We could end up doubling the I/O that is available on each PIC.
Ronald |
SherpaDoug
Posted: Tue Jul 24, 2007 8:57 am |
You might be able to do something if you can flash or PWM the LED. Connect a small capacitor (something like 0.01uf) from the PIC pin to the switch, and the switch to GND. If the switch is closed the LED and resistor will charge the cap to 5V in some amount of time determined by the resistor and capacitor values. If you turn on the LED briefly, but too brief to see, the cap will get discharged. Then make the PIC pin an input, wait a short time, and read the pin. If the switch is open the pin voltage will quickly return to 5V and you will read a "1". With the switch closed the pin voltage will rise more slowly and if the timing is right you will read a logic "0". The rest of the time you can use the pin to turn the LED on or off as required.
Working out the correct R, C, and timing is left as an exercise for the student.
T(seconds) = R(Ohms) x C(Farads) _________________ The search for better is endless. Instead simply find very good and get the job done. |
