Marc Guest
| help for c language |
Posted: Tue Jul 17, 2007 2:10 pm |
I need to define an array of strings and to initialize it with certain strings
There is a sintax error. Which?
char *pan_ids[5];
pan_ids[5]={"aaaa", "bbbb", "cccc", "dddd", "eeee"};
Thank You |
Bill Boucher
Joined: 04 Feb 2005 Posts: 34 Location: Chatham,ON,CA
Posted: Tue Jul 17, 2007 6:10 pm |
I don't think an array or string variable can be a pointer (as indicated by preceding *).
Also, "pan_ids[5]" can only hold 1 string such as "aaaa" at a time. If you want it to hold 5 strings, then you need a multi-dimensional array such as "pan_ids [5] [5]".
Try
| Code: | char pan_ids[5][5]={"aaaa", "bbbb", "cccc", "dddd", "eeee"};
If the strings are fixed (won't change) then stick "const" in your declaration to store the string data in program memory space instead of ram. |
kender
Posted: Tue Jul 17, 2007 7:45 pm |
| Bill Boucher wrote: | | I don't think an array or string variable can be a pointer (as indicated by preceding *). |
I think, Marc is trying to create an array of pointers to strings. There's no conceptual difference between an array variable and a pointer to the 1st member in the array.
| Marc wrote: | | Code: | | pan_ids[5]={"aaaa", "bbbb", "cccc", "dddd", "eeee"}; |
This will not work for 3 reasons.
1. You are trying to assign the whole array to a single slot.
2. ... and this slot is out of bounds of the array. The largest index is four (4).
3. The assignment syntax array[]={<member list>} works only during the initialization of the array. Afterwards you need to assign each array memer individually. If only need to initialize the array, you can do this (note that C counts the members in the initialization list, so there is no number in the brackets):
| Code: | | char* pan_ids[] = {"aaaa", "bbbb", "cccc", "dddd", "eeee"}; |
And finally, please read Kernigan & Ritchie. You will do yourself a huge favor. http://www.cs.bell-labs.com/cm/cs/cbook/ _________________ Read the label, before opening a can of worms.
