reading two a/d channels
chris_1982
PostPosted: Fri Mar 21, 2003 2:15 pm     Reply with quote
<font face="Courier New" size=-1>I am trying to read from two a/d channels on my 16F877. I am using the standard inbuilt read_adc() function. I set the channel then delay for 100ms before i take the reading BUT I can not read both channels within 1 program (both channels work if only 1 is being read within the program)
Has anyone got any suggestions as to errors I may have made.
I am using the PCM 3.023 compiler I have added the setup and read sections of my code below
thanks
chris
#Device ADC=10
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_internal);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
set_adc_channel(0);
adc=read_adc();
set_adc_channel(1);
adc=read_adc();</font>
___________________________
Original Post ID: 12931
Neutone
Re: reading two a/d channels
PostPosted: Fri Mar 21, 2003 2:57 pm     Reply with quote
:=<font face="Courier New" size=-1>I am trying to read from two a/d channels on my 16F877. I am using the standard inbuilt read_adc() function. I set the channel then delay for 100ms before i take the reading BUT I can not read both channels within 1 program (both channels work if only 1 is being read within the program)
:=Has anyone got any suggestions as to errors I may have made.
:=I am using the PCM 3.023 compiler I have added the setup and read sections of my code below
:=thanks
:=chris
:=#Device ADC=10
:= setup_adc_ports(ALL_ANALOG);
:= setup_adc(ADC_CLOCK_internal);
:= setup_spi(FALSE);
:= setup_psp(PSP_DISABLED);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_ccp1(CCP_OFF);
:= setup_ccp2(CCP_OFF);
:= set_adc_channel(0);
:= delay_ms(100);
:= adc=read_adc();
:= set_adc_channel(1);
:= delay_ms(100);
:= adc=read_adc();</font>
Ask CCS to provide you with a newer compiler version. Your code should work.
Original Post ID: 12934
