Interrupts
Freddie
Interrupts
PostPosted: Tue Oct 28, 2008 8:04 pm     Reply with quote
I'm trying to understand how interrupts work. Is there a good tutorial somewhere?
Question #1
To turn on the INT_TIMER1 is it better to do this:
or this:
Question #2
After the following code runs will INT_TIMER0 and INT_TIMER1 be enabled or do you have to reenable each one again separately?
disable_interrupts(GLOBAL);
Rohit de Sa
PostPosted: Tue Oct 28, 2008 9:44 pm     Reply with quote
Freddie,
I enable the individual interrupts first and then the global interrupt. So I use
Disabling a particular peripheral interrupt bit has no effect on other bits or the global bit. Similarly, even when the global is disabled, the timer1 and timer0 remain enabled.
Rohit
dbotkin
PostPosted: Tue Oct 28, 2008 10:54 pm     Reply with quote
Also, having the interrupts disabled doesn't disable the interrupt flags - it only means they have no effect on program execution. You can still test, for example, the Timer0 interrupt flag (T0IF), even if global and Timer0 interrupts are disabled. Similarly, an interrupt can wake up the PIC from sleep even if global interrupts are disabled.
That comes in handy some times.
Freddie
PostPosted: Wed Oct 29, 2008 4:43 pm     Reply with quote
Thanks. A few more questions...
So what does enable_interrupts(GLOBAL) actually do then?
So if the interrupts are disabled, how do you clear the TMR0IF flag?
PostPosted: Wed Oct 29, 2008 5:29 pm     Reply with quote
enable_interrupts(GLOBAL) modifies the global interrupt bit in processor status register.
The methods to reset the interrupt flags are documented in detail in the hardware manuals. Some are reset implicitely, e. g. by reading a data register, others have to be reset explicitely.
PostPosted: Wed Oct 29, 2008 5:48 pm     Reply with quote
Download the 16F-series PIC Reference manual on interrupts:
http://ww1.microchip.com/downloads/en/DeviceDoc/31008a.pdf
Look at the interrupt logic schematic on page 4. The global enable
bit (GIE) is the last enable in the chain. It controls everything.
You can see this clearly in the schematic.
Look at the clear_interrupt() function in the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Also note that CCS puts in code at the end of the INT_TIMER0 interrupt
service routine to automatically clear that bit. You don't have to put in
code to do it.
