joven
Joined: 30 Jan 2007 Posts: 56 Location: Viana do Castelo - Portugal
| USB bootloader |
Posted: Fri Apr 20, 2007 5:25 am |
Hi
I'm testing the usb bootloader, but i haven't sucess.
In the fuses have #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN,WRTB
When load the hex file don't give-me any warnings.
the problem is I don't know exactly i have to put for #org and #build.
i have tested some i found in the forum and didn't work.
Someone can help-me?
Thanks |
NicolasC
Posted: Fri Apr 20, 2007 5:39 am |
Hello
This is what I have in my main .c file for a PIC18F2550
#include "bootloader.h"
bootloader.h
#if defined(__PCM__)
#define LOADER_END 0x1FF
//#define LOADER_SIZE 0x1BF
#elif defined(__PCH__)
#define LOADER_END 0x7FF
//#define LOADER_SIZE 0x6FF
#ifndef _bootloader
#define _bootloader
#build(reset=LOADER_END+1, interrupt=LOADER_END+5)
#build(reset=LOADER_END+2, interrupt=LOADER_END+9)
#org 0, LOADER_END void bootloader(void) {}
#endif |
Regards |
joven
Posted: Fri Apr 20, 2007 8:35 am |
i'm using 18F4550 the memory is the same?
Isn't working.
the message of PSUSB is nÂș 6 the indicator is invalid.
What can be? |
meereck
Posted: Tue Apr 24, 2007 5:18 am |
The USB bootloader stopped to work after you had downloaded an user application, I guess.
I had several problems with fuses as well. I found out that when Pdfsusb application asks you what to do with the fuses, I have to click on "Cancel". Otherwise the bootloader sometimes stopped to work.
Flash a PIC with the bootloader again and use the following stencil for an user application (change your USB settings in fuses):
#include <18f2455.h>
#device ADC=10 // 10 bits return value from ADC
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL6,CPUDIV1,VREGEN,NOPBADEN,WRTB,MCLR,NOCPD,NOWRTC
#use delay(clock=48000000)// full speed USB device
#use rs232(baud=19200,xmit=PIN_C6, rcv=PIN_C7, STREAM=RS232)
// START OF bootloader definition
#build(reset=LOADER_END+1, interrupt=LOADER_END+9)
#org 0, LOADER_END {} // nothing will replace the bootloader memory space
// END OF bootloader definition
#define TICKS_PER_SECOND 183 //183 how often per second is timerirq routine called
byte timing = 0;
#int_rtcc
void timerirq()
if(++timing==TICKS_PER_SECOND){fprintf(RS232,"irq\r\n");
timing=0;output_toggle(PIN_B0);}
fprintf(RS232,"load\r\n");
output_low(PIN_B0);
set_timer0(0);
setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
enable_interrupts(INT_RTCC);
joven
softjad
Posted: Thu Jun 21, 2007 4:27 pm |
How can I use this bootloader in automatic mode (without manual reset...)?
Thanks |
joven
