thall Guest
| clear screen function |
Posted: Thu Jun 21, 2007 7:39 am |
| Is there a clear screen function (clrscr) for the CCS compiler? |
treitmey
Posted: Thu Jun 21, 2007 8:12 am |
Do you mean to clear an LCD screen?
Tell us which LCD your using.
Most people do this themself and just reset the screen or
send it spaces. |
SparkyEE
| Re: clear screen function |
Posted: Thu Jun 21, 2007 8:38 am |
| thall wrote: | | Is there a clear screen funtion(clrscr) for the CCS compiler? |
If you want to "clear screen" when on a RS-232 UART port. Just print a "form feed"
printf("\f"); |
thall Guest
Posted: Thu Jun 21, 2007 9:31 am |
| Sending ADC conversion values to a PC through RS232. I have a printf in a loop to constantly update the conversion values. I need a way to clear the data after each loop, in order to keep the conversion values on one line. |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Thu Jun 21, 2007 9:40 am |
Using ANSI Escape codes will clear the screen
fprintf( stream, "\x1B[2J" );
future
Posted: Thu Jun 21, 2007 5:41 pm |
| Look for those escape codes and instead of clearing the screen you should reposition the cursor and overwrite the old reading with a new one. |
