| Manah Guest
				| 16F628A and SETUP_ADC_PORTS(NO_ANALOGS) |
				|  Posted: Fri Jun 15, 2007 11:07 pm |   |
				| Hello.
  	  | Code: |  	  | #include <16F628A.h>
 #FUSES HS                       //High speed Osc (> 4mhz)
 #FUSES NOPUT                    //No Power Up Timer
 char ch[20];
 int dat;
 output_high(PIN_B7);
 output_low(PIN_B4);
 SETUP_ADC_PORTS(NO_ANALOGS);
 #use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_A3,bits=8)
 while (getc() != 'A');
 dat = getc();
 #use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
 putc(dat);
 Compiler: Undefined identifier SETUP_ADC_PORTS
 What is wrong?
