| View previous topic :: View next topic   |
			fastlink30
				| TRIS C |
				 Posted: Mon Jun 04, 2007 4:19 am     |
				16f877 pcwh 4.033
why after set_tris_c() the result is 0?
i use pn c6/7 for serial i/o and fast i/o.
void main() {
   int8 car;
   int16 tmp;
   int8 mot;
   char buff[6];
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   port_b_pullups(FALSE);
   set_tris_a(0b00000000);
   set_tris_b(0b00000000);
   set_tris_c(0b10000000);// 0 = output
printf("%u \r",get_tris_c());
			fastlink30
				 Posted: Tue Jun 05, 2007 10:18 am     |
				i tried also
   set_tris_b(0b10000011);
   set_tris_c(0b10000011);
printf("[%u %u] \r",get_tris_b(),get_tris_c());
result:
[131 0]
set_Tris_c() seems dont change value
where i'm wrong? maybe i don't disable somethng? |
			fastlink30
				 Posted: Tue Jun 05, 2007 10:33 am     |
				found the problem!
if i hide
#use fast_io(C)
all work ok....  but why? i can't use fast_io on port c? |
				 Posted: Tue Jun 05, 2007 12:23 pm     |
				In fast_io mode, the get_tris_c() function returns 0.   It doesn't read
the TRISC register or a shadow register.  It just returns 0. That's a bug.
Here's the ASM code produced for fast_io mode.
Notice that it loads W with 0x00 and then puts
W into 'tmp'.
...  set_tris_c(0b10000000);
000D:  MOVLW  80
000E:  MOVWF  07      // TRISC = 0x80
...  tmp = get_tris_c();
000F:  MOVF   00,W    // W = 0x00
0010:  BCF    03.5    // Bank 0
0011:  MOVWF  21      // tmp = W  (tmp = 0x00)
But it works OK for Port B:
... set_tris_b(0b10000000);
0012:  MOVLW  80
0013:  BSF    03.5
0014:  MOVWF  06     // TRISB = 0x80
... tmp = get_tris_b();
0015:  MOVF   06,W   // Read TRISB
0016:  BCF    03.5
0017:  MOVWF  21     // Put it into 'tmp'
Reading TRISC works OK if you don't enable fast_io mode
for Port C.   Then it reads the TRIS from the Shadow register.
000D:  MOVLW  FF
000E:  BCF    03.5
000F:  MOVWF  20
0010:  MOVLW  80
0011:  BSF    03.5
0012:  MOVWF  07
0013:  BCF    03.5
0014:  MOVWF  20
0015:  MOVF   20,W    // Read shadow reg. for TRISC
0016:  MOVWF  21    // and put it in 'tmp'
It also does this with vs. 4.040. |
			fastlink30
				 Posted: Tue Jun 05, 2007 12:54 pm     |
				aha, thank you for the info,now understand
strange ccs haven't fixed this problem |
				 Posted: Tue Jun 05, 2007 1:04 pm     |
				| They may not know about it.    Report the bug to CCS tech support. |
			fastlink30
				 Posted: Thu Jun 07, 2007 10:26 am     |
				i do
they reported this bug will be solved in the next release |
