iedchan
| keypad driver..coding from port d to port c |
Posted: Sat Jun 02, 2007 2:16 am |
anyone knows how to change this keypad driver..so that i could used port c instead of port d?
//#byte port_d = 0x08
char get_key(void)
char t;
while (1) {
output_d (input_d() | 0xFF);
output_bit(PIN_D4,0);
if (input (PIN_D0) ==0);{
delay_ms(10);
return 'A';
if (input (PIN_D1) ==0){
delay_ms(10);
return '7';
if (input (PIN_D2) ==0){
delay_ms(10);
return '4';
if (input (PIN_D3) ==0){
delay_ms(10);
return '1';
output_bit(PIN_D5,0);
delay_ms(10);
return '0';
delay_ms(10);
return '8';
delay_ms(10);
return '5';
delay_ms(10);
return '2';
output_bit(PIN_D6,0);
delay_ms(10);
return 'B';
delay_ms(10);
return '9';
delay_ms(10);
return '6';
delay_ms(10);
return '3';
output_bit(PIN_D7,0);
delay_ms(10);
return 'C';
delay_ms(10);
return 'D';
delay_ms(10);
return 'E';
delay_ms(10);
return 'F';
else return '<';
inservi
Posted: Sat Jun 02, 2007 6:44 am |
You can try this code !
| Code: | #byte port_c = 0xF83 // depending on the microcontroleur 0xF83 is for a 18F452
#define keyboard port_c
#define keyboard_line0 PIN_C0
#define keyboard_line1 PIN_C1
#define keyboard_line2 PIN_C2
#define keyboard_line3 PIN_C3
#define keyboard_row0 PIN_C4
#define keyboard_row1 PIN_C5
#define keyboard_row2 PIN_C6
#define keyboard_row3 PIN_C7
#define setPort output_c (keyboard | 0xFF);
char get_key(void){
while (true) {
setPort
output_bit(keyboard_row0,0);
if (input (keyboard_line0) ==0);{
delay_ms(10);
return 'A';
if (input (keyboard_line1) ==0){
delay_ms(10);
return '7';
if (input (keyboard_line2) ==0){
delay_ms(10);
return '4';
if (input (keyboard_line3) ==0){
delay_ms(10);
return '1';
setPort
output_bit(keyboard_row1,0);
delay_ms(10);
return '0';
delay_ms(10);
return '8';
delay_ms(10);
return '5';
delay_ms(10);
return '2';
setPort
output_bit(keyboard_row2,0);
delay_ms(10);
return 'B';
delay_ms(10);
return '9';
delay_ms(10);
return '6';
delay_ms(10);
return '3';
setPort
output_bit(keyboard_row3,0);
delay_ms(10);
return 'C';
delay_ms(10);
return 'D';
delay_ms(10);
return 'E';
delay_ms(10);
return 'F';
else return '<';
I'm not try it but it is compiled without error.
Normaly, you need to change the #byte and the #define for use an other port.
dro _________________ in médio virtus |
