KAZMA Guest
| Cant multiple int16*int16 |
Posted: Mon Apr 09, 2007 2:46 am |
Hi
i have to multiple two unsigned int16 numbers.
unsigned int32 result;
unsigned int16 number1;
code is like this;
result=number1*number2;
then i am showing the result on LCD
if the number1 is greater then 300 (or equals) then the result is lower as 256*number2
for example
number1=10;
nuber2=105;
result=1050 this works fine
but
when number1=300;
number2=1;
result=44;
what am i missing |
Posted: Mon Apr 09, 2007 7:08 am |
Start by correcting your typing errors!. You are declaring 'number1' twice in what you post, and not showing the declaration of number2 at all. Now what you are seeing, implies that probably you have 'number1' really declared as an int (8 bit int), not an int16.
As a separate comment though, there is no point in declaring the result as int32 in what you show. By default, CCS, only return the low 16 bits of a 16*16 multiplication. If you want a 32bit result, then you need:
unsigned int16 number2;
number1=100;
number2=1050;
result=(int32)number1*number2;
This will correctly handle generating the 32bit result from the 16*16 multiplication.
KAZMA Guest
Posted: Mon Apr 09, 2007 7:34 am |
there are no type errors in my orginal code.
and i tried
i still get the same result.
thanks |
jecottrell
Posted: Mon Apr 09, 2007 8:25 am |
I would suggest that you listen to the suggestions of the pros that take a significant amount of time to help a lot of us amateurs. They see things immediately that we can't see after staring for hours. Telling one of them they are wrong will quickly get you a place on the 'ungrateful, do not assist' list.
| Quote: | | there are no type errors in my orginal code. |
There aren't?
Ttelmah was kind enough to point out an obvious error. Make the effort to listen.
Read the guidelines for posting and follow them.
If you are going to post code....
Use the code posting feature of the BB.
Disable HTML.
Cut and paste, don't re-type... |
rnielsen
Posted: Mon Apr 09, 2007 8:29 am |
Would it need to have both variables cased and be written like this:
| Code: | | result = (int32)number1 * (int32)number2; |
Just a quick thought.
Ronald |
jecottrell
Posted: Mon Apr 09, 2007 8:36 am |
I was wondering a similar thought.... out of ignorance I typically cast like this:
| Code: | | result = (int32)(number1 * number2); |
KAZMA Guest
Posted: Mon Apr 09, 2007 8:52 am |
Hi everyone
i solved the problem thanks everybody,
@jecottrell if you read it again i said
there are no type errors in my ORGİNAL code this here is just a sample,
and i didnt say to anyone they are wrong, i said just i dont any type errors
anyway
in my code i was generating the numbers from something other
unsigned int8 xx;
number1=xx*1000;
the problem was that the variable xx was int8 i changed the definition of variable xx to int16 then it worked
i was using CC5x there werent problems like this
thanks again |
Posted: Mon Apr 09, 2007 9:02 am |
| jecottrell wrote: | I was wondering a similar thought.... out of ignorance I typically cast like this:
Key is that in a mathematical operation, the work is done in the type of the 'highest' component. Hence if you multiply an int16 by an int16, the arithmetic is done using int16. However if you multiply an int32 by an int16, int32 arithmetic is used. So you only 'need' to cast one part, but casting both does no harm.
